Home » Modeling » TMF (Xtext) » Accessing to errors in a model file
Accessing to errors in a model file [message #1222147] Thu, 19 December 2013 19:24 Go to next message
Victor Noël is currently offline Victor NoëlFriend
I'm trying to access to the errors in my model at the JvmModelGenerator level, when internalDoGenerate is called: I, on purpose, made my BuilderParticipant shouldGenerate method always return true.
The way I thought was correct was using ErrorSafeExtensions.hasErrors method, but strangely, it seems that IElementIssueProvider returned by the IElementIssueProvider.Factory always contains a Data field which is null, even when there is errors in the file!
So, first, I'm wondering if it is not a bug, and second, if there is an alternative way of checking for errors for a given element (and recursively in its eContent).
Thank you!
Victor
Re: Accessing to errors in a model file [message #1222885 is a reply to message #1222147] Sat, 21 December 2013 18:35 Go to previous message
FYI,
In order to have the IElementIssueProvider work, one has to populate it as it is shown in XtendBuilderParticipant.
That did the trick for me Smile
Previous Topic:Nested annotations using XbaseWithAnnotations
Next Topic:Problem Referring to Existing EPackage
Current Time: Sun Jan 17 23:23:51 GMT 2021
Powered by FUDForum. Page generated in 0.01705 seconds
