Home » Modeling » EMF » [CDO] Connection Aware URI, how to use it in a ResourceSet
Re: [CDO] Connection Aware URI, how to use it in a ResourceSet [message #1221790 is a reply to message #1221781] |
Wed, 18 December 2013 12:44   |
Christophe Bouhier Messages: 937 Registered: July 2009 |
On 18-12-13 13:20, Christophe Bouhier wrote:
> mmmh... The ViewProviderTest in CDO tests does exactly this, wonder how
For URL to support protocols, there is this below, but it also requires
a handler etc.... I am really puzzled how connection aware URI in CDO is
supposed to work?
* The property which specifies the package prefix list to be scanned
* for protocol handlers. The value of this property (if any) should
* be a vertical bar delimited list of package names to search through
* for a protocol handler to load. The policy of this class is that
* all protocol handlers will be in a class called
<protocolname>.Handler,
* and each package in the list is examined in turn for a matching
* handler. If none are found (or the property is not specified), the
* default package prefix, sun.net.www.protocol, is used. The search
* proceeds from the first package in the list to the last and stops
* when a match is found.
private static final String protocolPathProp =
"java.protocol.handler.pkgs";
> it works? Is the protocol registered somehow?
> On 18-12-13 13:09, Christophe Bouhier wrote:
>> Hi,
>> I am trying to use connection aware URI in the form:
>> cdo.net4j.tcp://localhost:2036/repo_source/resource
>> cdo.net4j.tcp://localhost:2037/repo_target/resource
>> I would like to use these, in combination with a CDOViewProvider which
>> would process the URI and create the appropriate TCPConnector.
>> When I try to get a resource with a ResourceSet, however I get a
>> Malformed URL exception. the protocol 'cdo.net4j.tcp' is not accepted.
>> Is there anything special I need to do?
>> BTW, when I use a canonical URI in the form cdo://repo_source/resource
>> it works, but then I miss info like the port and Connector type..
>> Thanks!
>> Christophe
Re: [SOLVED][CDO] Connection Aware URI, how to use it in a ResourceSet [message #1221805 is a reply to message #1221790] |
Wed, 18 December 2013 13:14   |
Ok, solved. the CDONet4jUtil will register the factory with protocol:
cdo.net4.tcp etc... when in OSGI, when in a Unit test registration is
needed explicity.... bummer.
Map<String, Object> map =
Resource.Factory.Registry.INSTANCE.getProtocolToFactoryMap();
if (!map.containsKey(CDONet4jUtil.PROTOCOL_TCP))
map.put(CDONet4jUtil.PROTOCOL_TCP, CDOResourceFactory.INSTANCE);
> supposed to work?
>>> Hi,
>>> Thanks!
>>> Christophe
Re: [CDO] Connection Aware URI, how to use it in a ResourceSet [message #1221808 is a reply to message #1221807] |
Wed, 18 December 2013 13:16   |
On 18-12-13 14:15, Christophe Bouhier wrote:
> On 18-12-13 14:12, Eike Stepper wrote:
>> Am 18.12.2013 13:09, schrieb Christophe Bouhier:
>>> Hi,
>> Not if running with the extension registry. Have a look at
>> /org.eclipse.emf.cdo.net4j/plugin.xml
>> Does that help?
> Thanks Ed, I figured out the magic was done in CDONet4jUtil, but I am
> running from a JUnit test (without OSGI).
Oops thanks Eike!
>> Cheers
>> /Eike
>> http://www.esc-net.de
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
Re: [CDO] Connection Aware URI, how to use it in a ResourceSet [message #1227132 is a reply to message #1227045] |
Fri, 03 January 2014 16:29  |
Am 03.01.2014 12:30, schrieb Christophe Bouhier:
> On 03-01-14 09:09, Eike Stepper wrote:
>> Am 23.12.2013 15:25, schrieb Christophe Bouhier:
>>> One more question on this, is it possible to load the root resource
>>> with a connection aware URI?
>> I have never tried it. The root resource is in some ways not a normal
>> resource because it doesn't contain business objects. The folders and
>> resources it contains are EObjects in a technical sense, though.
>>> the following URI, doesn't return the root resource.
>>> "cdo.net4j.tcp/localhost:2036/repo_source/"
>> What does it return then?
> It throws an exception.
I suspect that we can fix that in AbstractCDOView. Please submit a bugzilla.
Cheers
/Eike
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException:
> org.eclipse.emf.cdo.util.InvalidURIException: Invalid URI "cdo.net4j.tcp://127.0.0.1:2036/repo_source/":
> java.lang.IllegalArgumentException: path is empty
> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
> at org.eclipse.emf.edapt.cdo.tests.CDOMigrationTestBase.clearCDORepositories(CDOMigrationTestBase.java:84)
> at org.eclipse.emf.edapt.cdo.tests.CDOMigrationTestBase.setUp(CDOMigrationTestBase.java:75)
> at junit.framework.TestCase.runBare(TestCase.java:139)
> at junit.framework.TestResult$1.protect(TestResult.java:122)
> at junit.framework.TestResult.runProtected(TestResult.java:142)
> at junit.framework.TestResult.run(TestResult.java:125)
> at junit.framework.TestCase.run(TestCase.java:129)
> at junit.framework.TestSuite.runTest(TestSuite.java:255)
> at junit.framework.TestSuite.run(TestSuite.java:250)
> at org.eclipse.emf.edapt.cdo.tests.CDOMigrationTestSuite.run(CDOMigrationTestSuite.java:80)
> at org.junit.internal.runners.JUnit38ClassRunner.run(JUnit38ClassRunner.java:84)
> at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
> at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
> at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
> at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
> at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
> at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
> Caused by: org.eclipse.emf.cdo.util.InvalidURIException: Invalid URI "cdo.net4j.tcp://127.0.0.1:2036/repo_source/":
> at org.eclipse.emf.internal.cdo.view.AbstractCDOView.registerProxyResource(AbstractCDOView.java:1380)
> at org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.registerProxy(CDOResourceImpl.java:1165)
> at org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.load(CDOResourceImpl.java:1074)
> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
> at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
> ... 20 more
> Caused by: java.lang.IllegalArgumentException: path is empty
> at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getResourceNodeID(AbstractCDOView.java:546)
> at org.eclipse.emf.internal.cdo.view.AbstractCDOView.registerProxyResource(AbstractCDOView.java:1365)
> ... 24 more
>> Cheers
>> /Eike
Cheers
/Eike
Current Time: Sat Jan 16 04:02:54 GMT 2021
Powered by FUDForum. Page generated in 0.01696 seconds
