Re: Can't Connect to ECF Server [message #1221831 is a reply to message #1221687] |
Wed, 18 December 2013 14:02   |
On 12/18/2013 09:37 AM, Liana Yusri wrote:
> I recently found out about Eclipse Communication Framework (ECF) but
> unfortunately, I can't use it. I can't join the session when I press the
> "Connect to ECF Generic Collaboration Group" button.
> I also tried the "eclipse.exe -console -application
> org.eclipse.ecf.provider.AppGenericServer 1234" but received error
> instead (Application "org.eclipse.ecf.provider.AppGenericServer" could
> not be found in the registry.).
> How do I solve this problem in order to connect to the server?
Hi Liana,
AFAIK there is no public server running anymore. So unless you run your
own server, you won't be able to connect.
M.
Re: Can't Connect to ECF Server [message #1221956 is a reply to message #1221687] |
Wed, 18 December 2013 20:47   |
Scott Lewis Messages: 1038 Registered: July 2009 |
Hi Liana
Liana Yusri wrote on Wed, 18 December 2013 03:37Hi,
I recently found out about Eclipse Communication Framework (ECF) but unfortunately, I can't use it. I can't join the session when I press the "Connect to ECF Generic Collaboration Group" button.
I also tried the "eclipse.exe -console -application org.eclipse.ecf.provider.AppGenericServer 1234" but received error instead (Application "org.eclipse.ecf.provider.AppGenericServer" could not be found in the registry.).
Btw, I'm using Eclipse Kepler.
Thanks in advance.
Regards.
Markus is correct...there is no longer a public collab/chat server for ECF. There are two reasons for this:
1) We don't currently have the admin support to be able to admin multiple public servers;
2) There are now quite a large number of different kinds of ECF server applications (e.g. server for collab app, server for remote services, event admin, alternative providers...e.g. r-osgi, jms, etc), and so problem 1 is quite a difficult one for us...i.e. we are forced to choose which servers to run...and for how long.
However, you can run an ECF generic server by running this command
eclipse.exe -console -application org.eclipse.ecf.server.generic.Server
This should produce console output like this:
osgi>
Generic server started with id=ecftcp://localhost:3282/server
You may then connect to this server within Eclipse's ECF Collaboration view with this ID: ecftcp://localhost:3282/server
Client connects should result in the server console output like this:
Client Connect Addr=/127.0.0.1:58050;ID=StringID[p8C7XCJ9HmHszEvrvaM8ftAL7Sg=];G
roup=/server
Note, that for thie org.eclipse.ecf.server.generic.Server application that you can specify a configURL to change the hostname/port/path of the server:
eclipse.exe -console -application org.eclipse.ecf.server.generic.Server -serverName ecftcp://localhost:3284/myserver
Note also that the org.eclipse.ecf.server.generic.Server app can be started/debuged from within Eclipse, and the source for the application is in this class: org.eclipse.ecf.server.generic.app.GenericServerApplication
Which is in this project/bundle: org.eclipse.ecf.server.generic. This project is in the ECF git repo here:
http://git.eclipse.org/c/ecf/org.eclipse.ecf.git/tree/server-side/bundles/org.eclipse.ecf.server.generic
Note also that we are doing some feature restructuring right now...see this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=409787
specifically around better supporting server/non-Eclipse uses of ECF.
FUDForum. Page generated in 0.02127 seconds
