Home » Modeling » TMF (Xtext) » MyObject Instead of <Generated>Impl classes from xtext grammar(MyObject Instead of <Generated>Impl classes from xtext grammar)
MyObject Instead of <Generated>Impl classes from xtext grammar [message #1221201] Tue, 17 December 2013 05:24 Go to next message
Ramu Mothukuru is currently offline Ramu MothukuruFriend
can i use my own object model in xtext ?,like i want the data assigned to my objects instead of <Generated>impl classes generated
thanks in advance
Ram
Re: MyObject Instead of <Generated>Impl classes from xtext grammar [message #1221777 is a reply to message #1221201] Wed, 18 December 2013 12:10 Go to previous messageGo to next message
Matthieu Wipliez is currently offline Matthieu WipliezFriend
Member
Hi Ram,
yep you can use your own Ecore model, see the documentation about http://www.eclipse.org/Xtext/documentation.html#ePackageImport
Matthieu
Re: MyObject Instead of <Generated>Impl classes from xtext grammar [message #1221810 is a reply to message #1221777] Wed, 18 December 2013 13:25 Go to previous message
Thank you very much Matthieu, i'll try that
Previous Topic:Cross reference problem during clean build
Next Topic:Possibly solved? EMF Compare - "resolution of uriFragment... failed"
Current Time: Wed Jan 27 02:01:49 GMT 2021
Powered by FUDForum. Page generated in 0.01731 seconds
