Home » Modeling » EMF » Initialize Xcore/XTextResourceFactory
Initialize Xcore/XTextResourceFactory [message #1220856] Sat, 14 December 2013 13:51 Go to next message
Martin Taal is currently offline Martin TaalFriend
I can read XCore files through a Resource/ResourceSet. This works fine when I run the Texo code generation in Eclipse (I
create a ResourceSet and through some auto-magic it creates the correct XcoreResource).
But it does not work when I run the code generation as a plugin-test case (the test has the xcore plugin and its
dependency in the launch config). In that case a XMIResource gets created which fails when reading the xcore file.
Is there some initialization or some specific Xtext/Xcore thing I need to/can do so that my ResourceSet correctly
resolves the xcore uri's?
My current code:
final ResourceSet rs = new ResourceSetImpl();
rs.getResourceFactoryRegistry().getExtensionToFactoryMap().put("ecore", //$NON-NLS-1$
new EcoreResourceFactoryImpl());
rs.setPackageRegistry(registry);
rs.getURIConverter().getURIMap().putAll(EcorePlugin.computePlatformURIMap(true));
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Initialize Xcore/XTextResourceFactory [message #1220864 is a reply to message #1220856] Sat, 14 December 2013 20:50 Go to previous messageGo to next message
I made some progress, adding the xcore.ui plugin (and its dependencies) reads the xcore files into a Resource. This
works mostly except for references across xcore files. The files are in the same directory, but the references are not
resolved it seems.
I only read one of the files in a resource (using resourceSet.createResource(..)), I expected the other file to be read
also when the references are resolved.
Should I somehow setup/configure the resourceset?
I attached the xcore files I use for testing.
gr. Martin
On 12/14/2013 02:51 PM, Martin Taal wrote:
> My current code:
The Netherlands
package org.eclipse.emf.texo.test.model.samples.sport.club
import org.eclipse.emf.texo.test.model.samples.sport.society.Society
class Club extends Society
contains Team[] teams
class Team
String name
refers Member[] members
class Member
String name
String lastName
int age
Gender gender
enum Gender
male, female
package org.eclipse.emf.texo.test.model.samples.sport.competition
import org.eclipse.emf.texo.test.model.samples.sport.club.Team
class Competition {
String name
refers Team[] teams
package org.eclipse.emf.texo.test.model.samples.sport.society
class Society
String name
Re: Initialize Xcore/XTextResourceFactory [message #1220965 is a reply to message #1220864] Mon, 16 December 2013 11:37 Go to previous messageGo to next message
Martin,
What URI are you using to load the resource? I ask because Xtext's
indexing infrastructure needs to determine which IJavaProject the
resource is in so that it can use the index for that Java project to
resolve cross file references...
> dependencies) reads the xcore files into a Resource. This works mostly
> directory, but the references are not resolved it seems.
> gr. Martin
>> Hi,
>> My current code:
>> //$NON-NLS-1$
Re: Initialize Xcore/XTextResourceFactory [message #1220970 is a reply to message #1220965] Mon, 16 December 2013 11:59 Go to previous messageGo to next message
Hi Ed,
Indeed that was the problem, I now make sure that the project is refreshed before I run the headless build. This seems
to help. Also the project has a xtext nature set that helps to.
gr. Martin
On 12/16/2013 12:37 PM, Ed Merks wrote:
> Martin,
> What URI are you using to load the resource? I ask because Xtext's indexing infrastructure needs to determine which
> IJavaProject the resource is in so that it can use the index for that Java project to resolve cross file references...
>> resolved it seems.
>> read also when the references are resolved.
>> gr. Martin
>>> Hi,
>>> My current code:
The Netherlands
Re: Initialize Xcore/XTextResourceFactory [message #1221259 is a reply to message #1220965] Tue, 17 December 2013 08:45 Go to previous messageGo to next message
Hi Ed,
Still struggling with xtext getting to identify other xcore files in the same project. I have tried different uris to
load the xcore resource (through a resourceset), for example:
/org.eclipse.emf.texo.modelgenerator.test/src/org/eclipse/emf/texo/modelgenerator/test/models/samples/sport-competition.xcore
where the first segment is the project name.
To give some context, I start a launch config which runs headless and then programmatically generates files based on
models read through resources. I can get to the IProject and other things. I also tried refreshing the dev project
programmatically before I load the resource (to hope that xtext would 'fire' on a refresh).
Is there a way that I can 'force' xtext to scan a certain directory/folder/project? Where does xtext store all the
resolved xcores/types?
gr. Martin
> Martin,
>> resolved it seems.
>> gr. Martin
>>> Hi,
>>> My current code:
The Netherlands
Re: Initialize Xcore/XTextResourceFactory [message #1222156 is a reply to message #1221259] Thu, 19 December 2013 19:46 Go to previous messageGo to next message
Martin,
Comments below.
On 17/12/2013 9:45 AM, Martin Taal wrote:
> Hi Ed,
> the same project. I have tried different uris to load the xcore
It should use platform:/resource/<project-name>/<path-in-project>
> then programmatically generates files based on models read through
> refreshing the dev project programmatically before I load the resource
It generally does that for any project with an Xtext nature.
> Where does xtext store all the resolved xcores/types?
Good question. I'm not sure. Somewhere in the workspace's .metadata...
> gr. Martin
>> Martin,
>>> resolved it seems.
>>> gr. Martin
>>>> Hi,
>>>> My current code:
>>>> //$NON-NLS-1$
Re: Initialize Xcore/XTextResourceFactory [message #1230712 is a reply to message #1222156] Sun, 12 January 2014 22:09 Go to previous messageGo to next message
Hi Ed,
Thanks, I am still struggling with that references between xcore files are not resolved when I read the xcore files in a
ResourceSetImpl. I even make sure that the xcore files are all read in the same resourceset. Also the xcore resource
contains contents with an XPackage and EPackage etc. Only the references between xcore files are not resolved.
I use platform uri's and I see that the resourceset has a resource with a uri like this:
platform:/resource/org.eclipse.emf.texo.modelgenerator.test/src/org/eclipse/emf/texo/modelgenerator/test/models/samples/sport-society.xcore
This seems to be all fine, but the resourceset also has a resource with this uri:
platform:/resource/org.eclipse.emf.ecore/model/Ecore.xcore'
and this resource has an error:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: java.io.FileNotFoundException:
/model/Ecore.xcore
The error in the xcore file is this:
XtextLinkingDiagnostic: null:5 Couldn't resolve reference to GenBase 'Society'.
This although the XClass Society is present in a XCoreresource in the same ResourceSet.
So I must still be doing something wrong but have no clue...
On 12/19/2013 08:46 PM, Ed Merks wrote:
> Martin,
> Comments below.
>> Hi Ed,
>> gr. Martin
>>> Martin,
>>>> resolved it seems.
>>>> gr. Martin
>>>>> Hi,
>>>>> Eclipse (I
>>>>> My current code:
The Netherlands
Re: Initialize Xcore/XTextResourceFactory [message #1231224 is a reply to message #1230712] Tue, 14 January 2014 05:16 Go to previous message
Martin,
Comments below.
On 12/01/2014 11:09 PM, Martin Taal wrote:
> Hi Ed,
> are not resolved when I read the xcore files in a ResourceSetImpl. I
> resourceset. Also the xcore resource contains contents with an
> not resolved.
It always seems problematic to keep them in a src folder because the
generator generates references to them in the plugin.xml and that src
folder won't exist in the binary plugin...
> with this uri:
That's a synthetic resource created on the fly. It doesn't really
physically exist...
> java.io.FileNotFoundException: /model/Ecore.xcore
> 'Society'.
> same ResourceSet.
When you're running the tests, is there really a workspace with those
resources in it?
Maybe it's good to have a look at the Xcore unit tests and how/why they
work...
You might want to use our setup tool to setup the Xcore environment for
that purpose: https://wiki.eclipse.org/Setup-Eclipse
>> Martin,
>> Comments below.
>>> Hi Ed,
>>> gr. Martin
>>>> Martin,
>>>>> resolved it seems.
>>>>> gr. Martin
>>>>>> Hi,
>>>>>> Eclipse (I
>>>>>> My current code:
>>>>>> //$NON-NLS-1$
Previous Topic:Why its happening? "Internal error occurred during Validation Job. Property is invalid."
Next Topic:How to obtain Resource URI's in-project relative path (for use in Xtext IGenerator IFileSystemAccess
Current Time: Mon Sep 23 00:31:08 GMT 2019
Powered by FUDForum. Page generated in 0.02299 seconds
