What is the problem in import GMF files in new eclipse workspace? [message #1220813] |
Fri, 13 December 2013 18:35 |
mostafa fard Messages: 5 Registered: December 2013 |
I created an editor with EMF and GMF. I created *.model, *.edit and *.diagram plug-ins. I sent these plug-ins for a friend but he had errors in importing. After a while, we found that the problem is in importing way...!!!
In my way, I use "File>Import" then select the plug-ins folder and finally import all plug-ins(*.model, *.edit and *.diagram) in one step. The result is a project without any error.
In my friend's way, he use "File>New>plugin-in project" and use "Use default location" to import plug-ins. He inserted plug-ins in right order(1-*.model 2-*.edit 3-*.diagram) in three steps. The result is a project with a lot of errors in running.{Errors are in the attached file} The errors say we don't have some functions in GMF's plug-in.
We both have the same config for OS, Eclipse, Install plug-ins and ...
What is the problem? In the both ways we are importing the same java files, but we have errors in the second way.
Attachment: Errors.rtf
(Size: 76.26KB, Downloaded 218 times)
FUDForum. Page generated in 0.03856 seconds
