MappedSuperclass methods not getting weaved [message #1220772] |
Fri, 13 December 2013 14:11 |
Matthew Marron Messages: 2 Registered: December 2013 |
If you have the following situation:
@MappedSuperclass
public abstract class BaseEntityObject {
private Integer myInt;
@Column(name = "SOME_COLUMN")
public Integer getSomeColumn() {
return myInt;
public void setSomeColumn(Integer value) {
myInt = value;
@Entity
public class EntityA extends BaseEntityObject {
private Integer myOverridingInt;
return myOverridingInt;
myOverridingInt = value;
@Entity
public class EntityB extends BaseEntityObject {
If EntityA's someColumn field gets weaved first, the BaseEntityObject's someColumn never gets weaved. However, if EntityB gets weaved first, both EntityA.someColumn and BaseEntityObject.someColumn get weaved.
This is because the static weaver builds up a list of 'unMapped' fields. When EntityA is weaved, the unMapped fields set becomes empty. So when the superclass (BaseEntityObject) gets processed, it never visits the 'someColumn' field for weaving.
Is there a bug for this? Should this be a bug? Or should mapped properties on base classes be required to be final?
From the eclpselink jar's manifest (for version info):
Manifest-Version: 1.0
Ant-Version: Apache Ant 1.7.1
Created-By: 17.0-b16 (Sun Microsystems Inc.)
Specification-Title: Eclipse Persistence Services
Specification-Vendor: Eclipse.org - EclipseLink Project
Specification-Version: 2.4.2
Implementation-Title: org.eclipse.persistence
Implementation-Vendor: Eclipse.org - EclipseLink Project
Implementation-Version: 2.4.2.v20130514-5956486
Release-Designation: EclipseLink 2.4.2
Premain-Class: org.eclipse.persistence.internal.jpa.deployment.JavaSEC
MPInitializerAgent
Main-Class: org.eclipse.persistence.Version
[Updated on: Fri, 13 December 2013 18:11] Report message to a moderator
FUDForum. Page generated in 0.03252 seconds
