Re: The problem with the transmission parameters in the dataset using mongodb mapreduce [message #1487597 is a reply to message #1220836] |
Wed, 26 November 2014 00:36 |
Jose Patricio Villarreal Messages: 2 Registered: November 2014 |
Junior Member |
Hi Linda, I tried making my MongoDB dinamicly using the "Command Expression" as said on this post at stackoverflow stackoverflow.com/questions/25024375/birt-mongodb-param but it dosen't work, because the birt interface will tell you, "At least one field must be selected." ... So, on the Command Expression, I couldn't do this... BTW I used an Aggregate function not the Map Reduce.
And on the "Property Binding", could find documentation to help my self fill out this part.
Questions:
If I can get this done with you help, will the result be a parametrized report, on wich I can select the parameters tu use or use on a drill down situation?
If so, can you be more specific on how doing this, or give me a guide were to read...
FUDForum. Page generated in 0.03577 seconds
