Home » Eclipse Projects » Nebula » Maximize animation and maven question(How to question on maximizing editor)
Maximize animation and maven question [message #1220551] Thu, 12 December 2013 14:19 Go to next message
Prasanna K is currently offline Prasanna KFriend
Member
I have used org.eclipse.ui.part.MultiEditor to show multiple editors side-by-side. In order to support a requirement where -the inner editor should slowly maximize when double clicked its title- was wondering if I could use Nebula library. Please guide.
Also where can I get maven dependency info (group id, artifact id, version and repository) to fetch nebula jars through a maven based RCP application?
Thanks.
Maven question [message #1220564 is a reply to message #1220551] Thu, 12 December 2013 14:35 Go to previous messageGo to next message
Mickael Istria is currently offline Mickael IstriaFriend
> application?
What do you call a "maven based RCP application"? The closest thing from
Maven/RCP is Tycho, and Tycho doesn't require maven
groupId/artifactId/version to resolve dependencies. It relies on p2
repostories and p2 mechanisms. With Tycho consuming Nebula bundles is
done exactly the same way as consuming Eclipse platform bundles.
Mickael Istria
My job: http://www.jboss.org/tools
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: Maven question [message #1220571 is a reply to message #1220564] Thu, 12 December 2013 15:02 Go to previous message
Member
Mickael - we haven't moved to Tycho still. We use maven to pull the dependencies and build the plug-in jar by doing maven->install.
Previous Topic:Select all in Grid
Next Topic:IntensityGraph, when the axis are updated?
Current Time: Mon Nov 28 02:25:24 GMT 2022
Powered by FUDForum. Page generated in 0.02228 seconds
