Home » Modeling » EMF » EObjectValidator not being regenerated after chnage to xsd
EObjectValidator not being regenerated after chnage to xsd [message #1220456] Wed, 11 December 2013 20:53 Go to next message
drew frantz is currently offline drew frantzFriend
Here is the recipe:
- Open my.genmodel
- Reload (from xml schema)
- save genmodel
- generate model
- generate edit
The EObjectValidator in the util dir does not get regenerated with the new
elements from the xsd. Is there something else that needs to be done to
force regeneration of the validator?
Re: EObjectValidator not being regenerated after chnage to xsd [message #1220477 is a reply to message #1220456] Thu, 12 December 2013 04:27 Go to previous messageGo to next message
Drew,
Unless you add named constraints to you model, I don't expect any
validator to be generated. All the standard constraints supported for
XSD are supported direct by EObjectValidator itself, without a generated
subclass.
On 11/12/2013 9:53 PM, Drew wrote:
> Here is the recipe:
> - Open my.genmodel
> - save genmodel
> - generate model
> - generate edit
> new elements from the xsd. Is there something else that needs to be
> done to force regeneration of the validator?
Ed Merks
Re: EObjectValidator not being regenerated after chnage to xsd [message #1220549 is a reply to message #1220477] Thu, 12 December 2013 14:13 Go to previous message
Ok. So by adding a dummy named constraint the new validator methods get
generated. Now I get it.
thanks
"Ed Merks" <ed.merks@xxxxxxxx> wrote in message
news:l8bdvi$ss6$2@xxxxxxxxe.org...
> Drew,
> validator to be generated. All the standard constraints supported for XSD
> subclass.
>> Here is the recipe:
>> - Open my.genmodel
>> - save genmodel
>> - generate model
>> - generate edit
>> new elements from the xsd. Is there something else that needs to be done
Previous Topic:[EMF] Is there a standard model modelling only data types (without operations)
Next Topic:Linking of EObjects from different resources, detect saves
Current Time: Thu Sep 24 12:13:16 GMT 2020
Powered by FUDForum. Page generated in 0.02187 seconds
