Home » Modeling » EMF » Custom Property dialog
Custom Property dialog [message #1220432] Wed, 11 December 2013 17:30 Go to next message
Phil H is currently offline Phil HFriend
I've created a custom property dialog for one of my properties. Within this dialog, I'm able to add elements, as you can see here:
index.php/fa/16997/0/
I've realised this through an AddCommand:
EditingDomain editingDomain = org.eclipse.emf.edit.domain.AdapterFactoryEditingDomain.getEditingDomainFor(fm);
Command cmdRequiredConstraint = AddCommand.create(editingDomain, fm, PldPackage.Literals.FEATURE_MODEL__INTERNAL_CONSTRAINTS,constraint);									editingDomain.getCommandStack().execute(cmdRequiredConstraint);
This works fine so far, but when I'm saving my file, close it and open it again, the properties are removed:
index.php/fa/16998/0/
What can be the problem?
nother thing which doesn't work is deleting elements. I tried, accordingly to the AddCommand, remove eleemnts via the RemoveCommand, which doesn't work:
Command cmdDeleteConstraint = RemoveCommand.create(editingDomain, constraint);
editingDomain.getCommandStack().execute(cmdDeleteConstraint);
I also tried the DeleteCommand, which has the same effect. Why is adding elements working and deleting not?
Phil
Re: Custom Property dialog [message #1220438 is a reply to message #1220432] Wed, 11 December 2013 17:49 Go to previous messageGo to next message
Phil,
Are
On 11/12/2013 6:30 PM, Phil H wrote:
Is this a containment reference or a non-containment reference?
> Cheers,
> Phil
Ed Merks
Re: Custom Property dialog [message #1220442 is a reply to message #1220438] Wed, 11 December 2013 18:44 Go to previous messageGo to next message
I think this is a containment reference?:
class FeatureM{
  ref VariantConstraint[*] internalConstraints;
Re: Custom Property dialog [message #1220444 is a reply to message #1220442] Wed, 11 December 2013 19:03 Go to previous messageGo to next message
Perhaps you can make sure. It sounds to me more like it's
non-containment and that you're creating dangling references that can't
be saved.
> class FeatureM{
Ed Merks
Re: Custom Property dialog [message #1220445 is a reply to message #1220444] Wed, 11 December 2013 19:15 Go to previous messageGo to next message
Hmm, It's odd for me then that this references are shown in the property descriptor. Shouldn't this be a sign, that this references are correct?
Is this meant by a non-containment reference?:
class FeatureM{
class VariantConstraint{
  ref FeatureM featureM;
[Updated on: Wed, 11 December 2013 19:17]
Report message to a moderator
Re: Custom Property dialog [message #1220476 is a reply to message #1220445] Thu, 12 December 2013 04:25 Go to previous messageGo to next message
Phil,
Yes, if it downs up as having a property descriptor by default, it's a
cross reference.
> are correct?
Ed Merks
Re: Custom Property dialog [message #1220989 is a reply to message #1220476] Mon, 16 December 2013 14:26 Go to previous messageGo to next message
Hmm, so when I remove
from VariantConstraint it should work, because it's no non-containment reference anymore?
I tried this, but it still doesn't work. Maybe I haven't understand the context really..
Re: Custom Property dialog [message #1220997 is a reply to message #1220989] Mon, 16 December 2013 15:05 Go to previous messageGo to next message
Phil,
Comments below.
> reference anymore?
I can't say what the syntax you're using implies in terms of an Ecore model.
If you add to a containment reference it can't possibly end up being a
dangling reference so something must work differently.
That may be, but you've also not told me enough about the context for me
to tell you more.
Ed Merks
Re: Custom Property dialog [message #1222758 is a reply to message #1220997] Sat, 21 December 2013 09:25 Go to previous messageGo to next message
Ok I'll try to give you a clearer view about my context. As already mentioned in the first post, I've customized the normal property dialog for one of my elements. To call my custom dialog, I've provided my own implementation of PropertySource:
public class ProductLinePropertySource extends PropertySource {
	public ProductLinePropertySource(Object object,
			IItemPropertySource itemPropertySource) {
		super(object, itemPropertySource);
	protected IPropertyDescriptor createPropertyDescriptor(
			IItemPropertyDescriptor itemPropertyDescriptor) {
		PldPackage pkg = PldPackage.eINSTANCE;
		Object obj = itemPropertyDescriptor.getFeature(object);
		if (pkg.getFeatureModel_InternalConstraints().equals(obj)) {
			return new ConstraintPropertyDescriptor(object, itemPropertyDescriptor);
		} else {
			// Else, default EMF behavior
			return super.createPropertyDescriptor(itemPropertyDescriptor);
Inside my PropertyDescriptor, I'm calling my custom dialog:
public class ConstraintPropertyDescriptor extends PropertyDescriptor {
	public ConstraintPropertyDescriptor(Object object,
		super(object, itemPropertyDescriptor);
	public CellEditor createPropertyEditor(Composite parent) {
		return new ExtendedDialogCellEditor(parent, getLabelProvider()) {
			protected Object openDialogBox(Control cellEditorWindow) {
				Shell shell = Display.getCurrent().getActiveShell();
				if (object instanceof FeatureModel) {
					FeatureModel fm = (FeatureModel) object;
					ConstraintDialog dialog = new ConstraintDialog(fm, shell);
					dialog.open();
				return null;
Whereas my custom dialog allows to add properties to the element, as realizes in the add and delete buttons.
As shown in the the first post, the add command seems to work, while the delete command has no affect.
protected Control createDialogArea(final Composite parent) {
		final Composite container = (Composite) super.createDialogArea(parent);
		btnAddConstraint.addSelectionListener(new SelectionAdapter() {
			public void widgetSelected(SelectionEvent event) {
				VariantConstraint constraint = PldFactory.eINSTANCE.createVariantConstraint();
				constraint.setConstraintType(ConstraintType.EXCLUDE);
				Command cmdRequiredConstraint = AddCommand.create(editingDomain, fm, PldPackage.Literals.FEATURE_MODEL__INTERNAL_CONSTRAINTS, constraint);
		btnDeleteConstraint.addSelectionListener(new SelectionAdapter() {
				StructuredSelection constraintSelection = (StructuredSelection) lvConstraints.getSelection();
				VariantConstraint constraint = (VariantConstraint) constraintSelection.getFirstElement();
	return container;
Re: Custom Property dialog [message #1228564 is a reply to message #1222758] Tue, 07 January 2014 14:02 Go to previous message
Any further comments on this? Unfortunately I haven't solved this yet.
Previous Topic:Prevent generation of DocumentRoot Java class
Next Topic:[CDO] loading resources and package registration.
Current Time: Sun Oct 25 17:58:33 GMT 2020
Powered by FUDForum. Page generated in 0.02277 seconds
