Home » Eclipse Projects » DTP » DB2 10.1 FP 0 or DB2 10.5 not show schema in Data Explorer(DB2 10.1 FP 0 or DB2 10.5 not show schema in Data Explorer)
DB2 10.1 FP 0 or DB2 10.5 not show schema in Data Explorer [message #1220420] Wed, 11 December 2013 16:24 Go to next message
Marcos Wilceki is currently offline Marcos WilcekiFriend
after DB2 10.1 Fix Pack 0 ou DB2 10.5
Data Source Explorer does not show schema or tables in the database schema even though it connected to the database.
index.php/fa/16996/0/
Re: DB2 10.1 FP 0 or DB2 10.5 not show schema in Data Explorer [message #1252158 is a reply to message #1220420] Fri, 21 February 2014 01:04 Go to previous messageGo to next message
Brian Payton is currently offline Brian PaytonFriend
Hi, this problem has been fixed in DTP 1.10.2. (Kepler SR2)
The DTP IBM "enablement" plugins (org.eclipse.datatools.enablement.ibm.xxx) have been reworked to include a catalog loader that is specific to DB2 for LUW. Previously it was using the default (Derby) catalog loader, which does not work for DB2 releases after v9.5.
Re: DB2 10.1 FP 0 or DB2 10.5 not show schema in Data Explorer [message #1252174 is a reply to message #1252158] Fri, 21 February 2014 01:23 Go to previous message
Sorry, I meant DTP 1.11.2, not 1.10.2.
Previous Topic:SQL Results error when removing results
Next Topic:Can't browse DBMS that does not support schemas
Current Time: Fri Feb 26 01:32:28 GMT 2021
Powered by FUDForum. Page generated in 0.02106 seconds
