Re: Error management issue with Eclipse Parallel [message #1220470 is a reply to message #1220351] |
Thu, 12 December 2013 01:53 |
On 12/11/2013 06:12 AM, Lu Zamb wrote:
> Hi all,
> I'm using Eclipse for Parallel Application Developers (Kepler Service
> Release 1). I have a C project on my local machine (Window 7) and I'm
> trying to build it on a remote machine (Linux OS). When I build it, and
> an error is returned, if I click on the error, Eclipse doesn't jump to
> the line in the code related to the error. After some analysis, I think
> the problem is related to my Makefile:
> obj-m := module.o
> kernelver ?= $(shell uname -r)
> PWD ?= $(shell pwd)
> KERNELDIR ?= /lib/modules/$(kernelver)/build
> modules:
> $(MAKE) -C $(KERNELDIR) M=$(PWD) modules
> Since the file module.c is not built in its directory on the remote
> machine (but in the directory /lib/modules/$(kernelver)/build of the
> remote machine), all the errors will be returned refferred to an
> absolute path
> /root/module.ptp/module.c:8403: error: ...
> (root/module.ptp is the directory containing the project on the remote
> machine) instead of a relative path. So, Eclipse will be not able to
> link the error with the related code line on the local machine.
> Is there any solution to solve this issue?
> Regards,
> Lu
Sticky post at top of this forum:
http://www.eclipse.org/forums/index.php/t/161206/
FUDForum. Page generated in 0.03765 seconds
