Home » Eclipse Projects » NatTable » Create Body Context Menu in E4 with NatTable
Create Body Context Menu in E4 with NatTable [message #1220045] Mon, 09 December 2013 10:50 Go to next message
Ludwig Moser is currently offline Ludwig MoserFriend
I'm trying to register a Context Menu for NatTable.
therefore i use the EMenuService, NatTable and a MenuID.
e4popupMenu = menuService.registerContextMenu(natTable, menuId);
this returns me null.
so i thought i do need an existing menu on NatTable:
popupMenu = new Menu(natTable.getShell(), SWT.POP_UP);
natTable.setMenu(popupMenu);
now i can access my menu from code, but via extension its not visible by using the MenuID
what am i doing wrong here?
any help wellcome! thanks in advance!
Re: Create Body Context Menu in E4 with NatTable [message #1220050 is a reply to message #1220045] Mon, 09 December 2013 11:12 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
I'm not sure. NatTable itself has no dependency to the Eclipse framework. Maybe that is why it is not possible via extension point.
Why don't you use the popup menus in NatTable itself? This will give you access to the context like the current cell the click is performed on.
Re: Create Body Context Menu in E4 with NatTable [message #1220052 is a reply to message #1220050] Mon, 09 December 2013 11:34 Go to previous messageGo to next message
i need to be able to add menu items by extensions (commands)
eg. i add an command which exports my data to a specific format (eg. csv or something else)
one command exports the selection; the other exports all items in table, another one deletes the items selected;
etc...
i already had this stuff working with E3 (there i used the MenuManager)
to the function registerContextMenu i can find anything which shows that the swt component needs any dependencies to the eclipse framework. from what i read it just has to be a swt component which can hold an Menu...
Re: Create Body Context Menu in E4 with NatTable [message #1220054 is a reply to message #1220052] Mon, 09 December 2013 11:44 Go to previous messageGo to next message
Would need to investigate on this myself.
Could it be related to not performed injections?
Re: Create Body Context Menu in E4 with NatTable [message #1220058 is a reply to message #1220054] Mon, 09 December 2013 11:56 Go to previous messageGo to next message
nope. the only thing i get injected is the EMenuService, and this one is not null.
i checked this like 10 times, before posting here. all parameters are filled and not null.
eg:
		public EclipsePopupMenuBuilder(EMenuService menuService, NatTable natTable,
			String menuId) {
		System.out.println("building an PopupMenu for NatTable:");
		System.out.println("\tmenuId: " + menuId);
		System.out.println("\tmenuService: " + menuService);
		System.out.println("\tnatTable: " + natTable);
		if (menuService != null) {
			popupMenu = new Menu(natTable.getShell(), SWT.POP_UP); // testing
			natTable.setMenu(popupMenu);// testing
			System.out.println("\te4popupMenu : "
					+ e4popupMenu);
			System.out.println("\tswt menu : "
					+ popupMenu);
and the output:
	menuId: at.biooffice.views.site.listview.menu
	menuService: org.eclipse.e4.ui.workbench.swt.modeling.MenuService@146e54c
	natTable: NatTable {}
	e4popupMenu : null
	swt menu : Menu {}
hope this helps
[Updated on: Mon, 09 December 2013 12:03]
Report message to a moderator
Re: Create Body Context Menu in E4 with NatTable [message #1220126 is a reply to message #1220058] Mon, 09 December 2013 21:22 Go to previous messageGo to next message
Did you add a Popup Menu in the Application Model for your Part?
Debugging into MenuService you will notice that it will return null if there can be no menu found for the given ID for the current Part.
Re: Create Body Context Menu in E4 with NatTable [message #1220146 is a reply to message #1220126] Tue, 10 December 2013 06:18 Go to previous messageGo to next message
FYI i am not creating the app by using Application.e4xmi. i launch my app with an .product.
i added a extension point
org.eclipse.ui.menus
menu:xxx.views.listview.menu
xxx.views.listview.menu is the MenuID i pass in the register function
Re: Create Body Context Menu in E4 with NatTable [message #1220164 is a reply to message #1220146] Tue, 10 December 2013 07:26 Go to previous messageGo to next message
You also have a .product when working with an Application.e4xmi
I don't think your issue is related to NatTable. It sounds more like an issue with E4, compatibility layer and context menus in general. Maybe you want to ask you question in the E4 forum.
Re: Create Body Context Menu in E4 with NatTable [message #1220167 is a reply to message #1220164] Tue, 10 December 2013 07:53 Go to previous messageGo to next message
will do so, thanks!
How to fire ListEvent from GlazedListsEventLayer [message #1695141 is a reply to message #1220045] Tue, 12 May 2015 09:26 Go to previous message
Girish Bhat is currently offline Girish BhatFriend
Helped me too Smile
[Updated on: Tue, 12 May 2015 09:28]
Previous Topic:Frozen Columns - Drawing error
Next Topic:Gerrit enabled for NatTable
Current Time: Mon Feb 17 04:12:46 GMT 2020
Powered by FUDForum. Page generated in 0.01938 seconds
