Home » Eclipse Projects » Hudson » hudson job failing
hudson job failing [message #1219910] Fri, 06 December 2013 16:21 Go to next message
nagesh shenishetty is currently offline nagesh shenishettyFriend
We are new to hudson, when we are running job in hudson getting below error. Can any one please help us to resolve the issue ASAP.
Found mavenVersion 3.1.1 from file jar:file:/usr/local/apache-maven/apache-maven-3.1.1/lib/maven-core-3.1.1.jar!/META-INF/maven/org.apache.maven/maven-core/pom.properties Parsing POMs [testapp] $ /usr/java/jdk1.7.0_45/bin/java -cp /var/lib/hudson/plugins/maven-plugin/WEB-INF/lib/maven3-agent-3.0.0.jar:/usr/local/apache-maven/apache-maven-3.1.1/boot/plexus-classworlds-2.5.1.jar org.jvnet.hudson.maven3.agent.Maven3Main /usr/local/apache-maven/apache-maven-3.1.1 /var/lib/hudson/war/webapp/WEB-INF/lib/hudson-remoting-3.0.1.jar /var/lib/hudson/plugins/maven-plugin/WEB-INF/lib/maven3-interceptor-3.0.0.jar 54736 <===[HUDSON REMOTING CAPACITY]===>���channel started Executing Maven: -B -f /var/lib/hudson/jobs/New Maven Job1/workspace/branches/testapp/pom.xml install java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:330) at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:238) at org.jvnet.hudson.maven3.agent.Maven3Main.launch(Maven3Main.java:146) at hudson.maven.Maven3Builder.call(Maven3Builder.java:124) at hudson.maven.Maven3Builder.call(Maven3Builder.java:71) at hudson.remoting.UserRequest.perform(UserRequest.java:107) at hudson.remoting.UserRequest.perform(UserRequest.java:41) at hudson.remoting.Request$2.run(Request.java:276) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471) at java.util.concurrent.FutureTask.run(FutureTask.java:262) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:744) Caused by: java.lang.NoClassDefFoundError: org/apache/maven/cli/MavenLoggerManager at org.jvnet.hudson.maven3.launcher.Maven3Launcher.main(Maven3Launcher.java:73) ... 17 more Caused by: java.lang.ClassNotFoundException: org.apache.maven.cli.MavenLoggerManager at org.codehaus.plexus.classworlds.strategy.SelfFirstStrategy.loadClass(SelfFirstStrategy.java:50) at org.codehaus.plexus.classworlds.realm.ClassRealm.unsynchronizedLoadClass(ClassRealm.java:259) at org.codehaus.plexus.classworlds.realm.ClassRealm.loadClass(ClassRealm.java:235) at org.codehaus.plexus.classworlds.realm.ClassRealm.loadClass(ClassRealm.java:227) ... 18 more channel stopped ERROR: Failed to parse POMs hudson.util.IOException2: java.lang.reflect.InvocationTargetException at hudson.maven.Maven3Builder.call(Maven3Builder.java:189) at hudson.maven.Maven3Builder.call(Maven3Builder.java:71) at hudson.remoting.UserRequest.perform(UserRequest.java:107) at hudson.remoting.UserRequest.perform(UserRequest.java:41) at hudson.remoting.Request$2.run(Request.java:276) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471) at java.util.concurrent.FutureTask.run(FutureTask.java:262) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:744) Caused by: java.lang.Exception: java.lang.reflect.InvocationTargetException at org.jvnet.hudson.maven3.agent.Maven3Main.launch(Maven3Main.java:150) at hudson.maven.Maven3Builder.call(Maven3Builder.java:124) ... 9 more Caused by: java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:330) at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:238) at org.jvnet.hudson.maven3.agent.Maven3Main.launch(Maven3Main.java:146) ... 10 more Caused by: java.lang.NoClassDefFoundError: org/apache/maven/cli/MavenLoggerManager at org.jvnet.hudson.maven3.launcher.Maven3Launcher.main(Maven3Launcher.java:73) ... 17 more Caused by: java.lang.ClassNotFoundException: org.apache.maven.cli.MavenLoggerManager at org.codehaus.plexus.classworlds.strategy.SelfFirstStrategy.loadClass(SelfFirstStrategy.java:50) at org.codehaus.plexus.classworlds.realm.ClassRealm.unsynchronizedLoadClass(ClassRealm.java:259) at org.codehaus.plexus.classworlds.realm.ClassRealm.loadClass(ClassRealm.java:235) at org.codehaus.plexus.classworlds.realm.ClassRealm.loadClass(ClassRealm.java:227) ... 18 more Finished: FAILURE
Nagesh S
Re: hudson job failing [message #1222554 is a reply to message #1219910] Fri, 20 December 2013 19:07 Go to previous messageGo to next message
Winston Prakash is currently offline Winston PrakashFriend
There is an issue with maven 3.1.1 which we are working with Sonatype (maven guys) to fix. Would suggest to use maven 3.0.5
Winston Prakash
Eclipse Hudson team
Re: hudson job failing [message #1236366 is a reply to message #1219910] Mon, 27 January 2014 02:56 Go to previous messageGo to next message
maka srinivasa rao is currently offline maka srinivasa raoFriend
Please let me know, is this issue is resolved?. I am getting same error.
Re: hudson job failing [message #1284987 is a reply to message #1236366] Sat, 05 April 2014 03:28 Go to previous messageGo to next message
Did try with maven3-plugin 3.0.3?
Winston Prakash
Eclipse Hudson team
Re: hudson job failing [message #1498439 is a reply to message #1284987] Thu, 04 December 2014 12:01 Go to previous messageGo to next message
Fabrizio Giudici is currently offline Fabrizio GiudiciFriend
Any news on this? Unfortunately I have a couple of projects that use a plugin that requests Maven 3.1.1 - can't use 3.0 with them.
Thanks.
Fabrizio Giudici - Java Architect @ Tidalwave s.a.s.
"We make Java work. Everywhere."
Re: hudson job failing [message #1506598 is a reply to message #1498439] Thu, 11 December 2014 00:30 Go to previous message
This should be fixed in the latest git plugin. Did you try maven3 plugin version 3.0.4?
Winston Prakash
Eclipse Hudson team
Previous Topic:GIT - clean checkout fails
Next Topic:Node priority
Current Time: Mon Oct 26 08:34:11 GMT 2020
Powered by FUDForum. Page generated in 0.02477 seconds
