Re: [ATL] Library in EMFTVM launch config? [message #1219860 is a reply to message #1219782] |
Fri, 06 December 2013 10:20 |
Gunnar Arndt Messages: 82 Registered: June 2012 |
Member |
Dennis, thanks for the hint. I'm not yet sure how to transfer that exactly to my problem.
The importing module is in
/com.customer.dat.modeltransformation.startek/src/com/customer/dat/modeltransformation/startek/atl/files/transformate2startek.atl
and the library to be loaded is in
/com.customer.dat.modeltransformation.startek.atl.lib/src/com/customer/dat/modeltransformation/atl/lib/presenterLib.atl
I'm using
/com.customer.dat.modeltransformation.startek.atl.lib/src/com/customer/dat/modeltransformation/atl/lib/,/com.customer.dat.modeltransformation.startek/src/com/customer/dat/modeltransformation/startek/atl/files/
as module path in the launch config, and I'm not sure how to modify the library's name and the import in the using module. Can you specify your suggestion further?
[Updated on: Fri, 06 December 2013 10:20] Report message to a moderator
Re: [ATL] Library in EMFTVM launch config? [message #1853952 is a reply to message #1219782] |
Mon, 25 July 2022 13:30 |
Member |
I'm currently giving EMFTVM another try (after 9 years!).
The solution was to rename the importing project from
to
com.customer.dat.modeltransformation.startek.atl.files
so its name is no longer a prefix of the library project name
And of course add both comma-separated to the module path.
[Updated on: Mon, 25 July 2022 13:31] Report message to a moderator
FUDForum. Page generated in 0.03711 seconds
