[editor] UI remove class prefix when similar to package name [message #1219683] |
Thu, 05 December 2013 12:08 |
rodney medina Messages: 2 Registered: December 2013 |
Hi, (excuse me for my english)
I found a problem when reusing the model's name in a class's name.
Here an example :
model : Library.ecore
a class in the model : LibraryClass1
After generating the editor, the UI indicate only Class1.
I have noted that the file plugin.properties contain this error.
ex: _UI_LibraryClass1_type = Class1
Is this a bug, a naming convention or do i have to handle manually this problem ?
Merci d'avance.
[Updated on: Thu, 05 December 2013 13:45] Report message to a moderator
Re: [editor] UI remove class prefix when similar to package name [message #1219712 is a reply to message #1219683] |
Thu, 05 December 2013 14:22 |
You can change the type-name label that is generated for your EClass in
the plugin.properties file of your model's edit plug-in. EMF will not
overwrite your change if and when you later re-generate the model.
Look for the _UI_LibraryClass1_type key in the plugin.properties.
HTH,
Christian
> Here an example :
> I found that this issue came from the label modification :
> class LibraryWizard -> initialObjectField.add(getLabel(objectName));
> class DelegatingResourceLocator -> method getString(String key)
> problem ?
> Merci d'avance.
FUDForum. Page generated in 0.02689 seconds
