Home » Eclipse Projects » scout » Legacy security hint for
Legacy security hint for [message #1219649] Thu, 05 December 2013 08:41 Go to next message
Bertin Kiekebosch is currently offline Bertin KiekeboschFriend
How can I get rid of the following log message. I forgot and can't find the solution anymore.
Regards Bertin
!ENTRY org.eclipse.scout.rt.server 2 0 2013-12-05 09:36:06.583
!MESSAGE org.eclipse.scout.rt.server.DefaultTransactionDelegate.warnMissingInputValidation(DefaultTransactionDelegate.java:470) Legacy security hint for: nl.rid.atlas.shared.services.process.IDBCPrestatieCodeMPXVullenProcessService#vulDbcPrestatieCode: missing either annotation InputValidation or override of server-sideDefaultTransactionDelegate#findInputValidationStrategyByPolicy. To support legacy the QUERY strategy is used.
execTestConnection and check database application version
Re: Legacy security hint for [message #1219669 is a reply to message #1219649] Thu, 05 December 2013 10:44 Go to previous messageGo to next message
Matthias Villiger is currently offline Matthias VilligerFriend
Hi Bertin,
You can add the InputValidation annotation to the interface of your service:
e.g.
@InputValidation(IValidationStrategy.PROCESS.class)
if you want full checking.
See IValidationStrategy for the different validation strategies and their meaning.
regards,
matthias
Re: Legacy security hint for [message #1222026 is a reply to message #1219669] Thu, 19 December 2013 14:24 Go to previous messageGo to next message
marco giudici is currently offline marco giudiciFriend
Hi Matthias,
I think I have similar problem:
!ENTRY org.eclipse.scout.rt.server 2 0 2013-12-19 14:58:59.868
!MESSAGE org.eclipse.scout.rt.server.DefaultTransactionDelegate.warnMissingInputValidation(DefaultTransactionDelegate.java:470) Legacy security hint for: org.zeiss.mo.scout.CZVEDIController.shared.services.process.IDesktopProcessService#checkLockedFile: missing either annotation InputValidation or override of server-sideDefaultTransactionDelegate#findInputValidationStrategyByPolicy. To support legacy the QUERY strategy is used.
Please, can you explain me better how to use this "@inputvalidation" or foward me a link with explanation and example?
Thank you in advance for your help and explanation
Re: Legacy security hint for [message #1222354 is a reply to message #1222026] Fri, 20 December 2013 08:23 Go to previous messageGo to next message
to get rid of the message I added IValidationStrategy annotation to the interface of the process service.
Example:
public interface IDBCPrestatieCodeMPXVullenProcessService extends IService {
  DBCPrestatieCodeMPXVullenFormData prepareCreate(DBCPrestatieCodeMPXVullenFormData formData) throws ProcessingException;
  DBCPrestatieCodeMPXVullenFormData create(DBCPrestatieCodeMPXVullenFormData formData) throws ProcessingException;
  DBCPrestatieCodeMPXVullenFormData load(DBCPrestatieCodeMPXVullenFormData formData) throws ProcessingException;
  DBCPrestatieCodeMPXVullenFormData store(DBCPrestatieCodeMPXVullenFormData formData) throws ProcessingException;
  DBCPrestatieCodeMPXVullenFormData refreshGeselecteerdeDbcs(DBCPrestatieCodeMPXVullenFormData formData) throws ProcessingException;
regards Bertin
Re: Legacy security hint for [message #1222396 is a reply to message #1222354] Fri, 20 December 2013 10:12 Go to previous messageGo to next message
Hi Bertin,
I have a doubt because when I add
my Eclipse IDE show an error and ask me what I want to do (see image below)
index.php/fa/17104/0/
What is the right choice?
If I choose the first, that add the import, the error remain and say me
Class<PROCESS> cannot be resolved to a type
What am I missing?
The second ask me to create annotation, but onestly I don't know what I need to do.
I didn't try the third.
Can you help me to understand what is the correct way to exit from this doubt?
Thanks in advance for your help
  • Attachment: Immagine.png
    (Size: 24.64KB, Downloaded 315 times)
Re: Legacy security hint for [message #1225620 is a reply to message #1222396] Mon, 30 December 2013 10:06 Go to previous messageGo to next message
Hi Marco,
Your code is correct. You are just missing the required imports.
So to add all imports try to press ctrl+shift+o or use the context menu in the java editor having your interface file open: Source -> Organize Imports.
This should add the following import statements to your java file:
import org.eclipse.scout.rt.shared.validate.IValidationStrategy;
import org.eclipse.scout.rt.shared.validate.InputValidation;
Does this help?
matthias
Re: Legacy security hint for [message #1228479 is a reply to message #1225620] Tue, 07 January 2014 10:22 Go to previous message
Hi Matthias,
thank you for the explanation, has been of great help.
Previous Topic:Branding
Next Topic:working with org.eclipse.scout.rt.ui.rap.workbench
Current Time: Tue Sep 29 13:59:14 GMT 2020
Powered by FUDForum. Page generated in 0.02235 seconds
