Home » Eclipse Projects » NatTable » Scrolling by pixels programmatically
Scrolling by pixels programmatically [message #1219514] Wed, 04 December 2013 11:31 Go to next message
Istvan Meszaros is currently offline Istvan MeszarosFriend
Member
Hello all,
i need to synchronize the vertical scroll offset of a NatTable with another SWT component (not NatTable). The other component can be accurately scrolled by pixels (not rows).
To do the synchronization, i managed to set the row height of the NatTable to match the row height of the other component, but i don't know how to scroll the NatTable by pixels, and get the current scroll offset in pixels.
Thanks in advance!
Re: Scrolling by pixels programmatically [message #1219526 is a reply to message #1219514] Wed, 04 December 2013 12:10 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
Well unfortunately I don't know how to solve that. The scrolling by pixels was introduced in 1.0. There was never a request to scroll a NatTable programmatically by pixels.
You might want to have a look at the ViewportLayer which is responsible for scrolling. If it helps I could introduce getters for the connected IScroller. Not sure if that would help you in any way.
Re: Scrolling by pixels programmatically [message #1219528 is a reply to message #1219526] Wed, 04 December 2013 12:15 Go to previous messageGo to next message
Member
Thanks for the answer, i'll investigate the IScrollers to see if they help.
Re: Scrolling by pixels programmatically [message #1219532 is a reply to message #1219528] Wed, 04 December 2013 12:54 Go to previous messageGo to next message
Edwin Park is currently offline Edwin ParkFriend
To programmatically inspect the current viewport offset you can use ViewportLayer.getOrigin() which returns a PixelCoordinate. If you want to set the offset programmatically you can use the ViewportLayer's setOriginX() and setOriginY() methods to do so.
Edwin
Re: Scrolling by pixels programmatically [message #1240330 is a reply to message #1219532] Thu, 06 February 2014 08:38 Go to previous message
Member
Thanks, exactly what i was looking for.
Previous Topic:Reference of row objects
Next Topic:Change Icon in Text editor control decoration
Current Time: Wed Feb 26 10:38:53 GMT 2020
Powered by FUDForum. Page generated in 0.05276 seconds
