Home » Eclipse Projects » scout » Init before login dialog box
Init before login dialog box [message #1219474] Wed, 04 December 2013 04:58 Go to next message
Ranto ANDRIANJAFY is currently offline Ranto ANDRIANJAFYFriend
Hi all!
I have a scout app which required authentication, I want to know where to put my code if I want to initialize something before the login box appears.
Re: Init before login dialog box [message #1219692 is a reply to message #1219474] Thu, 05 December 2013 12:39 Go to previous message
Adrian Sacchi is currently offline Adrian SacchiFriend
Hi Ranto
The login box appears when your client application performs the first server call. Usually the first server call is performed in ClientSession.execLoadSession() when pre-loading the code types.
So any code that you write in the beginning of ClientSession.execLoadSession() will run before the login box appears.
  public void execLoadSession() throws ProcessingException {
    System.out.println("before login box");
    setServiceTunnel(new HttpServiceTunnel(this, getBundle().getBundleContext().getProperty("server.url")));
    //pre-load all known code types
    CODES.getAllCodeTypes(authfoo.shared.Activator.PLUGIN_ID);
    setDesktop(new Desktop());
    // turn client notification polling on
    // getServiceTunnel().setClientNotificationPollInterval(2000L);
Adrian
Previous Topic:Scout Version Matrix
Next Topic:Canceling a processing request (Busy handler custom implementation?)
Current Time: Thu Oct 29 20:18:06 GMT 2020
Powered by FUDForum. Page generated in 0.01886 seconds
