Home » Archived » Eclipse Process Manager (Stardust) » Maven repository links are broken
Maven repository links are broken [message #1219298] Tue, 03 December 2013 08:32 Go to next message
Benoit Guillon is currently offline Benoit GuillonFriend
It seems that the repositories referenced in the maven setup page are broken:
http://wiki.eclipse.org/Stardust/Knowledge_Base/Build_and_Change_Management/Maven/Basic_Setup
I get a 404 error when trying to access
http://download.eclipse.org/stardust/maven/releases
Thanks for your help
Benoit
Re: Maven repository links are broken [message #1219397 is a reply to message #1219298] Tue, 03 December 2013 16:27 Go to previous messageGo to next message
Robert Emsbach is currently offline Robert EmsbachFriend
Benoit,
this is normal. There simply is no page on the repository root, but the repository is not empty. You can browse the contents when you click on "Show Directory Contents." on that 404 page. Also the repo can be used with Maven.
Does that help?
Best regards
Rob
Re: Maven repository links are broken [message #1219491 is a reply to message #1219397] Wed, 04 December 2013 08:47 Go to previous message
Hi Robert,
I confirm I can see the repo content now.
Thanks for your help.
Best regards
Benoit
Previous Topic:Mail / SMTP / Authentication
Next Topic:Data Entity Beans can't resolve
Current Time: Fri Sep 25 01:53:43 GMT 2020
Powered by FUDForum. Page generated in 0.02965 seconds
