Home » Modeling » Graphiti » PropertyChangeListener in new View(How do I get notified of changed properties in the editor or properties view.)
PropertyChangeListener in new View [message #1218639] Fri, 29 November 2013 11:11 Go to next message
svdwoude V is currently offline svdwoude VFriend
Hi!
I'm writing a new view which should be notified of selection changes or property changes (for instance a name change) in the editor or properties view.
The selection changes are already handled in my view:
ISelectionListener listener = new ISelectionListener() {
		@SuppressWarnings("restriction")
		public void selectionChanged(IWorkbenchPart part, ISelection sel) {
      		if (sel instanceof IStructuredSelection) {
			IStructuredSelection ss = (IStructuredSelection) sel;
			Object o = ss.getFirstElement();
	        	if (o instanceof ContainerShapeEditPart) {
	        		ContainerShapeEditPart editPart = (ContainerShapeEditPart) o;
	        		IFeatureProvider fp = editPart.getFeatureProvider();
	        		selection = fp.getBusinessObjectForPictogramElement(editPart.getPictogramElement());
	        		castElement();
	        		createSuggestions();
	        	else {
	        		generateErrorInstruction(part, sel);
public void createPartControl(Composite parent) {
     getSite().getWorkbenchWindow().getSelectionService().addSelectionListener(listener);
Is there a way to get notified of property changes like that?
For instance: the moment you start typing a new name for an element in the diagram, I'd like to be notified.
Should I extract the name label of the selection and add a listener at that point? How should i go about this?
Thanks in advance.
Re: PropertyChangeListener in new View [message #1219201 is a reply to message #1218639] Mon, 02 December 2013 15:33 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
in order to achieve that you will have to register EMF Adapters to the
EObjects you want to observe. They will get notified as soon as the object
or its attributes change. There are numerous tutorials in the Web, e.g.
http://www.vogella.com/articles/EclipseEMFNotification/article.html
Michael
Re: PropertyChangeListener in new View [message #1219467 is a reply to message #1219201] Wed, 04 December 2013 02:15 Go to previous message
Thank you Michael!
You pointed me in the right direction.
If other people come across this problem, register a listener to your EObject like this:
((EObject)selection).eAdapters().add(new AdapterImpl() {
    public void notifyChanged(Notification msg) {
    // Execute change reaction code.
[Updated on: Wed, 04 December 2013 08:33]
Report message to a moderator
Previous Topic:Using polygons to replicate semicircles
Next Topic:Control Points for CurvedConnection
Current Time: Sun Jul 25 02:14:02 GMT 2021
Powered by FUDForum. Page generated in 0.02126 seconds
