automatic line number [message #197293] |
Mon, 23 October 2006 22:32 |
Originally posted by: wendy.fischer.airplaynetwork.com
How do you do line number for a table?
I have a table that needs to be numbered. I'm not sure how to do this.
Re: automatic line number [message #197327 is a reply to message #197293] |
Tue, 24 October 2006 07:29 |
Originally posted by: screek.gmx.de
if it is a table without grouping then you can simply use the RowNum
"column" of the table.
Try adding a dynamic text to the table, in the expression builder you will
find it in the category
"Available Column Bindings". The expression should look like row.__rownum
after you added the RowNum.
If it is a grouped table then please just have a look at the posting
"Numbering a grouped table". I just asked this question a few days ago and
the solution suggested is working very well.
Christian
"Wendy Fischer" <wendy.fischer@airplaynetwork.com> wrote in message
news:7d0e2e887598ada667656df893520a6c$1@www.eclipse.org...
FUDForum. Page generated in 0.01928 seconds
