Home » Eclipse Projects » GEF » GEF for standard SWT
GEF for standard SWT [message #197197] Thu, 29 September 2005 23:48 Go to next message
What would be involved from the GEF side to extend GEF to support an
arbitrary SWT Composite as a design surface?
I might need to do this for a client project I'm working on.
Best Regards,
Dave Orme
Visual Editor Project lead
http://www.db4o.com -- The Open-source Java Object Database
http://xswt.sf.net -- XML-based SWT page description language
Re: GEF for standard SWT [message #197224 is a reply to message #197197] Fri, 30 September 2005 08:55 Go to previous messageGo to next message
Originally posted by: sunil_kamath.nohotspammail.com
"David J. Orme" <djo@coconut-palm-software.com> wrote in message
news:dhichl$rhb$1@news.eclipse.org...
Create a FigureCanvas using the arbitrary SWT composite as the parent. ;-).
Would that work?
Sunil
Re: GEF for standard SWT [message #197239 is a reply to message #197197] Fri, 30 September 2005 09:34 Go to previous messageGo to next message
Originally posted by: john.obyrne.gmail.com
I have the same problem, I want to use GEF in a dialog, but I found no way
to use GEF without an Editor.
The only way I am thinking about would be to subclass the FigureCanvas and
add all the stuff present in the GraphicalViewerImpl class which extends
AbstractEditPartViewer and implements GraphicalViewer...
Pretty heavy stuff for me (I don't know GEF yet, I only know draw2D)
> Best Regards,
> Dave Orme
Re: GEF for standard SWT [message #197247 is a reply to message #197239] Fri, 30 September 2005 09:48 Go to previous messageGo to next message
I think I found a way:
Just use the ScrollingGraphicalViewer which seems to be done for that (it
takes a parent composite and instanciate a FigureCanvas)
"John O'Byrne" <john.obyrne@gmail.com> wrote in message
news:dhjetq$ah3$1@news.eclipse.org...
>> Best Regards,
>> Dave Orme
Re: GEF for standard SWT [message #197254 is a reply to message #197224] Fri, 30 September 2005 11:01 Go to previous messageGo to next message
> Would that work?
I think that's one step.
Another is probably to create an SWTFigure object implementing IFigure
that wraps an arbitrary SWT Control class. This is because things like
GraphicalEditPart#createFigure() want to return an IFigure.
The IFigure wrapper would have to buffer any non-default SWT object
property values, create/dispose the actual SWT peer on add()/remove(),
and map between the Draw2d and SWT event models...
Otherwise you have to reinvent the whole GraphicalEditPart hierarchy for
SWT. Ugh.
Hmmmm.... Seems doable though. And you'd have to do 80% of this
anyway if you wanted to implement an SWT GUI builder based on direct
manipulation of SWT controls... (Thinking about this because someone
else several threads up was wondering how to do it, not because VE is
planning to do it any time soon... :-)
Dave
Re: GEF for standard SWT [message #197404 is a reply to message #197254] Mon, 03 October 2005 11:35 Go to previous messageGo to next message
>> Would that work?
I think "design surface" was interpreted as the outer-most element.
Sure, lot's of people have asked for a figure that is a proxy to an SWT
Control. The lifecycle of the control would probably be managed outside of
the figure, such as by the editpart or something.
> property values, create/dispose the actual SWT peer on add()/remove(), and
Yuck. I don't think there is a generic way to extract the properties from a
Control when calling dispose. We would have to assume the control is around
the whole time.
Direct manipulation of heavyweight contrls would be too painful. You can't
paint on top of them, so there would be no handles or feedback.
Re: GEF for standard SWT [message #197419 is a reply to message #197404] Mon, 03 October 2005 11:44 Go to previous messageGo to next message
"Randy Hudson" <none@us.ibm.com> wrote in message
news:dhrj48$r8p$1@news.eclipse.org...
> [snip] Direct manipulation of heavyweight contrls would be too painful.
> You can't paint on top of them, so there would be no handles or feedback.
And this, IMHO, is the deal-killer.
Sunil
Re: GEF for standard SWT [message #200229 is a reply to message #197419] Fri, 21 October 2005 00:57 Go to previous message
There are ways to work around this. But I agree it isn't pretty.
(My GUI builder that pre-dated VE directly manipulated heavyweight
controls. But it's a moot point now that we have VE which uses GEF.)
Best,
Dave Orme
Previous Topic:Palette and Tree View
Next Topic:SWT's FormLayout ported to Draw2d
Current Time: Thu Jul 17 12:40:51 EDT 2025
Powered by FUDForum. Page generated in 0.06356 seconds
