| Compile only? [message #197080] |
Fri, 13 July 2007 19:05  |
Originally posted by: usenet.aristeia.com
Sometimes I don't want to build an entire project, I just want to compile the
current source file. I can't find a "compile this file only" option for doing
this. In fact, I can't find a "compile this project" option. Is there some way
to invoke something less than a full build?
Scott
| Re: Compile only? [message #197620 is a reply to message #197611] |
Tue, 17 July 2007 18:24  |
Scott Meyers wrote:
> drix wrote:
>> I have just discover than when the Project have the option to "Build
>> Automatically" checked, the "Build Selected File(s)" is not available.
>> When I uncheck it, the "Build Selected File(s)" is available and working
>> normally.
> This is the behavior I see, too. Thanks for figuring out what was going
> on.
> IMO, it should be possible to manually build a file even if automatic
> building is enabled.
> Scott
I agree with you that it should be possible to build a file in this context.
Just made another test and the behavior is not the same with a "Makefile
Project", the "Build Selected File(s)" is not available event if the
"Build Automatically" is disable, only the "Clean Selected File(s)" is
available, strange.
The bugzilla 192684 is about this problem, I will add my comment to it.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=192684
Drix
FUDForum. Page generated in 0.07997 seconds
