Creating a web service by WTP [message #196733] |
Thu, 19 July 2007 17:04 |
Originally posted by: zomithex1.yahoo.com
Hello Dear Friends,
I am trying to create a web service using WTP by going through the
"Eclipse Evaluation Guide".
http://www.eclipse.org/webtools/initial-contribution/IBM/eva lGuides/WebServicesToolsEval.html#tour-bu-prereqtomcat
in part 3.2.4 which is "Create a Web service and Web service client"
after step 8, which is the end of the configuration of the web service
before using it, I got this error:
"IWAB0213E Error in starting server
Detail:
org.eclipse.core.runtime.CoreException:
several ports(8005,8080,8009) required by Tomcat v6.0 server at localhost
are already in use. The server may already be running in another
process, or a system process may be using the port. To start this server
you will need to stop the other process or change the port number(s)".
I can run the Tomcat manually, seems noting is wrong with it.
And I am not using any other program which may use Tomcat server.
Do you have any idea what's wrong and what should I do?
Thanks a lot
Mitra
Re: Creating a web service by WTP [message #196767 is a reply to message #196733] |
Thu, 19 July 2007 20:01 |
Seng Phung Lu Messages: 62 Registered: July 2009 |
Member |
Hi Mitra,
When you are running Tomcat from WTP, is the other instance(outside of
Eclipse) also running? If so, there's likely a port sharing issue, and
you need to shutdown the outside server. Another option is to change
the WTP Tomcat configuration to use a different server port other than 8080.
I have used Tomcat5.0 and Tomcat5.5 (but not Tomcat v6.0) in this
scenario, so I can't rule out Tomcat v6.0 behaviour.
Hope that helps,
Seng
mitra wrote:
> Hello Dear Friends,
> Detail:
> localhost are already in use. The server may already be running in
> another process, or a system process may be using the port. To start
> this server you will need to stop the other process or change the port
> number(s)".
> Thanks a lot
> Mitra
Re: Creating a web service by WTP [message #196775 is a reply to message #196767] |
Thu, 19 July 2007 20:30 |
Originally posted by: zomithex1.yahooo.com
Dear Seng,
Would you please explain me a lil what you mean by "other instance" in
"is the other instance(outside of Eclipse) also running?" and "outside
server" in "you need to shutdown the outside server".
Sorry, but I have no idea what they really point to.
thanks a lot
Mitra
FUDForum. Page generated in 0.03730 seconds
