Home » Modeling » TMF (Xtext) » Two DSLs in one Eclipse project, only one is active(Noob)
Re: Two DSLs in one Eclipse project, only one is active [message #1215221 is a reply to message #1214951] |
Thu, 28 November 2013 01:42 |
Gary Worsham Messages: 176 Registered: September 2013 |
I decided to run validation on the plugins and came up with this.
Uploaded with ImageShack.us
Tried adding these to the dependencies in manifest.mf, but error persists.
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: spincad
Bundle-Vendor: Holy City Audio
Bundle-Version: 0.91
Bundle-SymbolicName: spincad;singleton:=true
Require-Bundle: org.eclipse.core.filebuffers;bundle-version="3.5.300",
org.eclipse.xtext.xbase;resolution:=optional;visibility:=reexport,
org.eclipse.xtext.generator;resolution:=optional,
org.eclipse.emf.mwe2.launch;resolution:=optional,
com.google.inject.source;bundle-version="3.0.0",
org.eclipse.xtext.junit4;bundle-version="2.4.3",
org.apache.log4j;bundle-version="1.2.15",
org.apache.commons.codec;bundle-version="1.4.0",
org.apache.commons.io;bundle-version="2.0.1",
org.apache.commons.lang;bundle-version="2.6.0",
org.apache.commons.lang3;bundle-version="3.1.0",
org.apache.commons.logging;bundle-version="1.1.1",
org.apache.commons.math;bundle-version="2.1.0",
org.apache.commons.pool;bundle-version="1.6.0",
org.apache.commons.primitives;bundle-version="1.0.0",
org.eclipse.xtext,
org.eclipse.xtext.util,
org.eclipse.emf.ecore,
org.eclipse.emf.common,
org.antlr.runtime,
org.eclipse.xtext.common.types,
org.eclipse.core.filebuffers.source;bundle-version="3.5.300"
Import-Package: org.apache.log4j,
org.eclipse.ui,
org.eclipse.xtext.xbase.lib
Bundle-RequiredExecutionEnvironment: JavaSE-1.7
Export-Package: com.holycityaudio.spincad,
com.holycityaudio.spincad.services,
com.holycityaudio.spincad.spinCAD,
com.holycityaudio.spincad.spinCAD.impl,
com.holycityaudio.spincad.spinCAD.util,
com.holycityaudio.spincad.serializer,
com.holycityaudio.spincad.parser.antlr,
com.holycityaudio.spincad.parser.antlr.internal,
com.holycityaudio.spincad.validation,
com.holycityaudio.spincad.scoping,
com.holycityaudio.spincad.generator,
com.holycityaudio.spincad.formatting
Re: Two DSLs in one Eclipse project, only one is active [message #1215737 is a reply to message #1215221] |
Thu, 28 November 2013 06:58 |
Hi at the place where you do the run as:
(Run -> Run Configurations -> choose yours under eclipse apps)
Open the config dialog goto the plugins tab and hit add required (if
you don't have chosen all in your case) there is a validate button
too.
Sorry there are too many options so it is extremely hard to help
BTW there should / maybe multiple/a manifest.mf_gen or
plugin.XML_gen you should compare with the companion without the gen
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Twitter : @chrdietrich
Current Time: Thu Apr 25 11:12:27 GMT 2024
Powered by FUDForum. Page generated in 0.03759 seconds
