Infinite loop in UI internal ANTLR parser [message #1214481] |
Wed, 27 November 2013 18:19  |
Christian Mauceri Messages: 22 Registered: May 2012 Location: Paris |
Hi, the ANTLR UI parser I get with the attached grammar enters an infinite loop when I call the content assist.
I put trace in the internal parser before calling each DFA and I cycle on rule__Block__Alternatives_2 as shown below, any idea why ? The line number printed by dfa70.getDescription() does not correspond to anything meaningful to me.
Any help would be really appreciated.
The input fragment corresponding to the loop is :
package test.base;
import model.A;
public class Urlu {
public static int zabab = 1;
public static String azba = "aaa";
public Urlu() {
A aa = new A();
int arbou = 1 ;
I should add the resulting parser java class is very huge, 190000 lines.
dfa70 9227:1: rule__Block__Alternatives_2 : ( ( ( rule__Block__Group_2_0__0 ) ) | ( ( rule__Block__ExpressionsAssignment_2_1 ) ) | ( ( rule__Block__ExpressionsAssignment_2_2 ) ) | ( ( rule__Block__ExpressionsAssignment_2_3 ) ) | ( ( rule__Block__ExpressionsAssignment_2_4 ) ) | ( ( rule__Block__ExpressionsAssignment_2_5 ) ) | ( ( rule__Block__ExpressionsAssignment_2_6 ) ) | ( ( rule__Block__ExpressionsAssignment_2_7 ) ) | ( ( rule__Block__ExpressionsAssignment_2_8 ) ) | ( ( rule__Block__ExpressionsAssignment_2_9 ) ) | ( ( rule__Block__ExpressionsAssignment_2_10 ) ) | ( ( rule__Block__ExpressionsAssignment_2_11 ) ) | ( ( rule__Block__ExpressionsAssignment_2_12 ) ) | ( ( rule__Block__ExpressionsAssignment_2_13 ) ) | ( ( rule__Block__ExpressionsAssignment_2_14 ) ) | ( ( rule__Block__ExpressionsAssignment_2_15 ) ) );
d
[Updated on: Wed, 27 November 2013 18:25] Report message to a moderator
FUDForum. Page generated in 0.02523 seconds
