Home » Eclipse Projects » Eclipse Scout » Browser field error in RAP client
Browser field error in RAP client [message #1213981] Wed, 27 November 2013 13:38 Go to next message
Dominic Hanlan is currently offline Dominic HanlanFriend
Member
I am opening a form with a browserfield in it which opens a location. I get the following error in the RAP client. The SWT client is fine. Is this related to the RAP cross-domain-scripting issue? Is there a fix?
Client Error
Details:
Error: Error: Operation "call" on target "w207" of type "rwt.widgets.Browser" failed:
SecurityRestriction:
Browser-Widget can not access "www.dentabyte.co.uk" from "localhost:8082".
Properties:
functions = scoutActivateLocalUrl
  Script: {"head":{"requestCounter":1},"operations":[["create","w2","rwt.widgets.Shell",{"style":["NO_TRIM"]}],["listen","w2",{"Move":true,"Resize":true,"Activate":true,"Close":true}],["set","w2",{"active":true,"mode":"maximized","minimumSize":[80,0],"activeControl":"w3","bounds":[0,0,1920,948],"children":["w3","w27","w63"],"tabIndex":-1,"visibility":true}],["create","w7","rwt.widgets.Menu",{"style":["POP_UP"]}],["create","w8","rwt.widgets.MenuItem",{"parent":"w7","style":["CASCADE"],"index":0,"text":"File","image":["rwt-resources/generated/fff9407c.png",16,16],"menu":"w9"}],["listen","w8",{"Selection":true}],["create","w11","rwt.widgets.MenuItem",{"parent":"w7","style":["CASCADE"],"index":1,"text":"Features","menu":"w12"}],["listen","w11",{"Selection":true}],["create","w16","rwt.widgets.MenuItem",{"parent":"w7","style":["CASCADE"],"index":2,"text":"Help","menu":"w17"}],["listen","w16",{"Selection":true}],["create","w9","rwt.widgets.Menu",{"style":["DROP_DOWN"]}],["create","w10","rwt.widgets.MenuItem",{"parent":"w9","style":["PUSH"],"index":0,"text":"Exit"}],["listen","w10",{"Selection":true}],["create","w12","rwt.widgets.Menu",{"style":["DROP_DOWN"]}],["create","w13","rwt.widgets.MenuItem",{"parent":"w12","style":["PUSH"],"index":0,"text":"Quality Management"}],["listen","w13",{"Selection":true}],["create","w14","rwt.widgets.MenuItem",{"parent":"w12","style":["PUSH"],"index":1,"text":"To Do List"}],["listen","w14",{"Selection":true}],["create","w15","rwt.widgets.MenuItem",{"parent":"w12","style":["PUSH"],"index":2,"text":"Manage Subscribers"}],["listen","w15",{"Selection":true}],["create","w17","rwt.widgets.Menu",{"style":["DROP_DOWN"]}],["create","w18","rwt.widgets.MenuItem",{"parent":"w17","style":["PUSH"],"index":0,"text":"About..."}],["listen","w18",{"Selection":true}],["create","w3","rwt.widgets.Composite",{"parent":"w2","style":["NONE"],"bounds":[0,0,1920,27],"children":["w4","w22","w23"],"tabIndex":-1}],["listen","w3",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w3",{"customVariant":"variant_toolbarContainer","clientArea":[0,0,1920,27]}],["create","w4","rwt.widgets.Composite",{"parent":"w3","style":["NONE"],"bounds":[0,0,317,27],"children":["w5","w19"],"tabIndex":-1}],["listen","w4",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w4",{"clientArea":[0,0,317,27]}],["create","w5","rwt.widgets.Composite",{"parent":"w4","style":["NONE"],"bounds":[3,0,40,25],"children":["w6"],"tabIndex":-1}],["listen","w5",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w5",{"clientArea":[0,0,40,25]}],["create","w6","rwt.widgets.Button",{"parent":"w5","style":["PUSH","FLAT"],"bounds":[0,0,40,25],"tabIndex":4,"menu":"w7"}],["listen","w6",{"FocusIn":true,"FocusOut":true,"KeyDown":true}],["set","w6",{"customVariant":"variant_menuButton"}],["listen","w6",{"Selection":true}],["create","w19","rwt.widgets.Composite",{"parent":"w4","style":["NONE"],"bounds":[46,0,271,27],"children":["w20","w21"],"tabIndex":-1}],["listen","w19",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w19",{"customVariant":"variant_toolbarContainer","clientArea":[0,0,271,27]}],["create","w20","rwt.widgets.Button",{"parent":"w19","style":["TOGGLE","FLAT"],"bounds":[3,0,116,27],"tabIndex":6,"activeKeys":["#13"],"cancelKeys":["#13"]}],["listen","w20",{"FocusIn":true,"FocusOut":true,"KeyDown":true}],["set","w20",{"customVariant":"variant_viewButton","text":"House Keeping"}],["listen","w20",{"Selection":true}],["create","w21","rwt.widgets.Button",{"parent":"w19","style":["TOGGLE","FLAT"],"bounds":[122,0,146,27],"tabIndex":7,"activeKeys":["#13"],"cancelKeys":["#13"]}],["listen","w21",{"FocusIn":true,"FocusOut":true,"KeyDown":true}],["set","w21",{"customVariant":"variant_viewButton-active","text":"Quality Management","selection":true}],["listen","w21",{"Selection":true}],["create","w22","rwt.widgets.Composite",{"parent":"w3","style":["NONE"],"bounds":[1097,5,17,17],"children":[],"tabIndex":-1,"visibility":false}],["listen","w22",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w22",{"customVariant":"variant_busyIndicator","clientArea":[8,8,1,1]}],["create","w23","rwt.widgets.Composite",{"parent":"w3","style":["NONE"],"bounds":[1894,24,26,3],"children":["w24","w25","w26"],"tabIndex":-1}],["listen","w23",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w23",{"customVariant":"variant_toolButtonBar","clientArea":[0,0,26,3]}],["create","w24","rwt.widgets.Button",{"parent":"w23","style":["PUSH","FLAT"],"bounds":[0,0,0,0],"tabIndex":10,"visibility":false}],["listen","w24",{"FocusIn":true,"FocusOut":true,"KeyDown":true}],["set","w24",{"customVariant":"variant_toolButtonBarCollapseButton"}],["listen","w24",{"Selection":true}],["create","w25","rwt.widgets.Label",{"parent":"w23","style":["NONE"],"bounds":[0,0,0,0],"tabIndex":-1,"visibility":false}],["listen","w25",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w25",{"customVariant":"variant_toolButton","alignment":"center"}],["create","w26","rwt.widgets.Composite",{"parent":"w23","style":["NONE"],"bounds":[10,0,6,3],"children":[],"tabIndex":-1}],["listen","w26",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w26",{"customVariant":"variant_toolButtonBar","clientArea":[0,0,6,3]}],["create","w27","rwt.widgets.Composite",{"parent":"w2","style":["NONE"],"bounds":[0,27,1920,921],"children":["w28","w31","w34","w37","w40","w43","w46","w49","w52","w55","w56","w57","w58","w59","w60","w61","w62"],"tabIndex":12,"customVariant":"variant_viewsArea","clientArea":[3,3,1914,915]}],["create","w28","rwt.widgets.Composite",{"parent":"w27","style":["NONE"],"bounds":[3,3,474,766],"children":["w29","w30"],"tabIndex":13,"customVariant":"variant_viewPart","clientArea":[0,0,472,764]}],["create","w29","rwt.widgets.Composite",{"parent":"w28","style":["NONE"],"bounds":[0,0,0,64],"children":["w64"],"tabIndex":-1,"visibility":false}],["listen","w29",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w29",{"customVariant":"variant_formTabArea","clientArea":[0,0,0,64]}],["create","w64","rwt.widgets.Composite",{"parent":"w29","style":["NONE"],"bounds":[0,0,155,24],"children":["w65","w66"],"tabIndex":15,"customVariant":"variant_formTab","clientArea":[5,2,145,22]}],["create","w65","rwt.widgets.Button",{"parent":"w64","style":["PUSH","FLAT"],"bounds":[5,2,145,18],"tabIndex":16}],["listen","w65",{"FocusIn":true,"FocusOut":true,"KeyDown":true}],["set","w65",{"customVariant":"variant_formTabActivate","text":"Quality Management","image":["rwt-resources/generated/130a74ec.png",16,16]}],["listen","w65",{"Selection":true}],["create","w66","rwt.widgets.Button",{"parent":"w64","style":["PUSH","FLAT"],"bounds":[150,5,12,12],"tabIndex":17,"visibility":false}],["listen","w66",{"FocusIn":true,"FocusOut":true,"KeyDown":true}],["set","w66",{"customVariant":"variant_formTabClose"}],["listen","w66",{"Selection":true}],["create","w30","rwt.widgets.Composite",{"parent":"w28","style":["NONE"],"bounds":[0,0,472,764],"children":["w67"],"tabIndex":-1}],["listen","w30",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w30",{"clientArea":[0,0,472,764]}],["create","w67","rwt.widgets.Composite",{"parent":"w30","style":["NONE"],"bounds":[0,0,472,764],"children":["w68"],"tabIndex":-1}],["listen","w67",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w67",{"clientArea":[0,0,472,764]}],["create","w68","rwt.widgets.Composite",{"parent":"w67","style":["NONE"],"bounds":[0,0,472,764],"children":["w73","w69","w72"],"tabIndex":20,"foreground":[151,158,164,255],"font":[["Arial","Helvetica","sans-serif"],15,true,false],"clientArea":[0,0,472,764]}],["create","w73","rwt.widgets.Composite",{"parent":"w68","style":["NONE"],"bounds":[0,-1,472,1],"children":[],"tabIndex":-1,"background":[209,228,240,255],"clientArea":[0,0,472,1]}],["create","w69","rwt.widgets.Canvas",{"parent":"w68","style":["NONE"]}],["create","gc208","rwt.widgets.GC",{"parent":"w69"}],["set","w69",{"bounds":[0,0,472,0],"children":["w70"],"tabIndex":22,"visibility":false,"foreground":[151,158,164,255],"font":[["Arial","Helvetica","sans-serif"],15,true,false],"backgroundGradient":[[[255,255,255,255],[239,246,250,255]],[0,100],true],"clientArea":[0,0,472,0]}],["create","w70","rwt.widgets.Canvas",{"parent":"w69","style":["NONE"]}],["create","gc209","rwt.widgets.GC",{"parent":"w70"}],["set","w70",{"bounds":[0,1,0,0],"children":["w71"],"tabIndex":23,"visibility":false,"foreground":[151,158,164,255],"background":[0,0,0,0],"font":[["Arial","Helvetica","sans-serif"],15,true,false],"clientArea":[0,0,0,0]}],["create","w71","rwt.widgets.Label",{"parent":"w70","style":["WRAP"],"bounds":[0,0,0,0],"tabIndex":-1,"visibility":false,"foreground":[151,158,164,255],"background":[0,0,0,0],"font":[["Arial","Helvetica","sans-serif"],15,true,false]}],["create","w72","rwt.widgets.Composite",{"parent":"w68","style":["NONE"],"bounds":[0,0,472,764],"children":["w74"],"tabIndex":24,"foreground":[151,158,164,255],"clientArea":[0,0,472,764]}],["create","w74","rwt.widgets.Composite",{"parent":"w72","style":["NONE"],"bounds":[0,0,472,764],"children":["w75"],"tabIndex":-1}],["listen","w74",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w74",{"customVariant":"variant_form","clientArea":[0,0,472,764]}],["create","w75","rwt.widgets.Composite",{"parent":"w74","style":["NONE"],"bounds":[0,0,472,764],"children":["w76"],"tabIndex":-1,"activeKeys":["#27","#13","#13","#13"],"cancelKeys":["#13"]}],["listen","w75",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true,"KeyDown":true}],["set","w75",{"clientArea":[0,0,472,764]}],["create","w76","rwt.widgets.Composite",{"parent":"w75","style":["NONE"],"bounds":[0,0,472,764],"children":["w77"],"tabIndex":-1}],["listen","w76",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w76",{"clientArea":[0,0,472,764]}],["create","w77","rwt.widgets.Composite",{"parent":"w76","style":["NONE"],"bounds":[0,0,472,764],"children":["w78","w81"],"tabIndex":-1}],["listen","w77",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w77",{"clientArea":[0,0,472,764]}],["create","w78","rwt.widgets.Composite",{"parent":"w77","style":["NONE"],"bounds":[0,0,0,0],"children":["w79","w80"],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w79","rwt.widgets.Label",{"parent":"w78","style":["NONE"],"appearance":"clabel","bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"text":""}],["create","w80","rwt.widgets.Label",{"parent":"w78","style":["NONE"],"bounds":[0,3,0,15],"tabIndex":-1,"visibility":false}],["create","w81","rwt.widgets.Grid",{"parent":"w77","style":["SINGLE","FULL_SELECTION","BORDER"],"appearance":"tree","indentionWidth":20,"markupEnabled":true}],["create","w82","rwt.widgets.ScrollBar",{"parent":"w81","style":["HORIZONTAL"]}],["create","w83","rwt.widgets.ScrollBar",{"parent":"w81","style":["VERTICAL"]}],["set","w81",{"bounds":[0,0,472,764],"children":[],"tabIndex":31,"activeKeys":["#13","#32","#13"],"cancelKeys":["#13","#13"]}],["listen","w81",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true,"KeyDown":true,"MenuDetect":true}],["set","w81",{"itemCount":1,"itemHeight":23,"itemMetrics":[[0,0,320,0,16,22,290]],"focusItem":"w108","selection":["w108"]}],["listen","w81",{"Selection":true,"DefaultSelection":true,"Expand":true,"Collapse":true}],["listen","w82",{"Selection":true}],["listen","w83",{"Selection":true}],["create","w84","rwt.widgets.GridItem",{"parent":"w81","index":0,"itemCount":8,"texts":["Zones"],"images":[["rwt-resources/generated/130a74ec.png",16,16]],"expanded":true}],["create","w86","rwt.widgets.GridItem",{"parent":"w84","index":0,"itemCount":1,"texts":["Effective Leadership Management"],"images":[["rwt-resources/generated/7b3623c.png",24,24]]}],["create","w87","rwt.widgets.GridItem",{"parent":"w86","index":0}],["create","w88","rwt.widgets.GridItem",{"parent":"w84","index":1,"itemCount":1,"texts":["Marketing Stratergy"],"images":[["rwt-resources/generated/b3753b9c.png",24,24]]}],["create","w89","rwt.widgets.GridItem",{"parent":"w88","index":0}],["create","w90","rwt.widgets.GridItem",{"parent":"w84","index":2,"itemCount":3,"texts":["Patient Care"],"images":[["rwt-resources/generated/6dea0ff3.png",24,24]],"expanded":true}],["create","w102","rwt.widgets.GridItem",{"parent":"w90","index":0,"itemCount":1,"texts":["Patient Care Audits"],"images":[["rwt-resources/generated/130a74ec.png",16,16]]}],["create","w103","rwt.widgets.GridItem",{"parent":"w102","index":0}],["create","w104","rwt.widgets.GridItem",{"parent":"w90","index":1,"itemCount":1,"texts":["Completed Audits"],"images":[["rwt-resources/generated/130a74ec.png",16,16]]}],["create","w105","rwt.widgets.GridItem",{"parent":"w104","index":0}],["create","w106","rwt.widgets.GridItem",{"parent":"w90","index":2,"itemCount":4,"texts":["Action Plans"],"images":[["rwt-resources/generated/130a74ec.png",16,16]],"expanded":true}],["create","w108","rwt.widgets.GridItem",{"parent":"w106","index":0,"itemCount":1,"texts":["Created"],"images":[["rwt-resources/generated/130a74ec.png",16,16]]}],["create","w109","rwt.widgets.GridItem",{"parent":"w108","index":0}],["create","w110","rwt.widgets.GridItem",{"parent":"w106","index":1,"itemCount":1,"texts":["Reviewing"],"images":[["rwt-resources/generated/130a74ec.png",16,16]]}],["create","w111","rwt.widgets.GridItem",{"parent":"w110","index":0}],["create","w112","rwt.widgets.GridItem",{"parent":"w106","index":2,"itemCount":1,"texts":["Updating"],"images":[["rwt-resources/generated/130a74ec.png",16,16]]}],["create","w113","rwt.widgets.GridItem",{"parent":"w112","index":0}],["create","w114","rwt.widgets.GridItem",{"parent":"w106","index":3,"itemCount":1,"texts":["Published"],"images":[["rwt-resources/generated/130a74ec.png",16,16]]}],["create","w115","rwt.widgets.GridItem",{"parent":"w114","index":0}],["create","w92","rwt.widgets.GridItem",{"parent":"w84","index":3,"itemCount":1,"texts":["Risk Management"],"images":[["rwt-resources/generated/5e199304.png",24,24]]}],["create","w93","rwt.widgets.GridItem",{"parent":"w92","index":0}],["create","w94","rwt.widgets.GridItem",{"parent":"w84","index":4,"itemCount":1,"texts":["Quality Assurance"],"images":[["rwt-resources/generated/99e1ec1e.png",24,24]]}],["create","w95","rwt.widgets.GridItem",{"parent":"w94","index":0}],["create","w96","rwt.widgets.GridItem",{"parent":"w84","index":5,"itemCount":1,"texts":["Operational Efficiency"],"images":[["rwt-resources/generated/1b9f17f8.png",24,24]]}],["create","w97","rwt.widgets.GridItem",{"parent":"w96","index":0}],["create","w98","rwt.widgets.GridItem",{"parent":"w84","index":6,"itemCount":1,"texts":["Financial Success"],"images":[["rwt-resources/generated/c254a4d8.png",24,24]]}],["create","w99","rwt.widgets.GridItem",{"parent":"w98","index":0}],["create","w100","rwt.widgets.GridItem",{"parent":"w84","index":7,"itemCount":1,"texts":["Dream Team"],"images":[["rwt-resources/generated/10090ec1.png",24,24]]}],["create","w101","rwt.widgets.GridItem",{"parent":"w100","index":0}],["create","w31","rwt.widgets.Composite",{"parent":"w27","style":["NONE"],"bounds":[0,0,0,0],"children":["w32","w33"],"tabIndex":32,"visibility":false,"customVariant":"variant_viewPart","clientArea":[0,0,0,0]}],["create","w32","rwt.widgets.Composite",{"parent":"w31","style":["NONE"],"bounds":[0,0,0,64],"children":[],"tabIndex":-1,"visibility":false}],["listen","w32",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w32",{"customVariant":"variant_formTabArea","clientArea":[0,0,0,64]}],["create","w33","rwt.widgets.Composite",{"parent":"w31","style":["NONE"],"bounds":[0,64,0,0],"children":[],"tabIndex":-1,"visibility":false}],["listen","w33",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w33",{"clientArea":[0,0,0,0]}],["create","w34","rwt.widgets.Composite",{"parent":"w27","style":["NONE"],"bounds":[3,772,474,146],"children":["w35","w36"],"tabIndex":35,"customVariant":"variant_viewPart","clientArea":[0,0,472,144]}],["create","w35","rwt.widgets.Composite",{"parent":"w34","style":["NONE"],"bounds":[0,0,0,64],"children":["w116"],"tabIndex":-1,"visibility":false}],["listen","w35",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w35",{"customVariant":"variant_formTabArea","clientArea":[0,0,0,64]}],["create","w116","rwt.widgets.Composite",{"parent":"w35","style":["NONE"],"bounds":[0,0,76,24],"children":["w117","w118"],"tabIndex":37,"customVariant":"variant_formTab","clientArea":[5,2,66,22]}],["create","w117","rwt.widgets.Button",{"parent":"w116","style":["PUSH","FLAT"],"bounds":[5,2,66,17],"tabIndex":38}],["listen","w117",{"FocusIn":true,"FocusOut":true,"KeyDown":true}],["set","w117",{"customVariant":"variant_formTabActivate","text":"To Do List"}],["listen","w117",{"Selection":true}],["create","w118","rwt.widgets.Button",{"parent":"w116","style":["PUSH","FLAT"],"bounds":[71,4,12,12],"tabIndex":39,"visibility":false}],["listen","w118",{"FocusIn":true,"FocusOut":true,"KeyDown":true}],["set","w118",{"customVariant":"variant_formTabClose"}],["listen","w118",{"Selection":true}],["create","w36","rwt.widgets.Composite",{"parent":"w34","style":["NONE"],"bounds":[0,0,472,144],"children":["w119"],"tabIndex":-1}],["listen","w36",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w36",{"clientArea":[0,0,472,144]}],["create","w119","rwt.widgets.Composite",{"parent":"w36","style":["NONE"],"bounds":[0,0,472,144],"children":["w120"],"tabIndex":-1}],["listen","w119",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w119",{"clientArea":[0,0,472,144]}],["create","w120","rwt.widgets.Composite",{"parent":"w119","style":["NONE"],"bounds":[0,0,472,144],"children":["w125","w121","w124"],"tabIndex":42,"foreground":[151,158,164,255],"font":[["Arial","Helvetica","sans-serif"],15,true,false],"clientArea":[0,0,472,144]}],["create","w125","rwt.widgets.Composite",{"parent":"w120","style":["NONE"],"bounds":[0,-1,472,1],"children":[],"tabIndex":-1,"background":[209,228,240,255],"clientArea":[0,0,472,1]}],["create","w121","rwt.widgets.Canvas",{"parent":"w120","style":["NONE"]}],["create","gc210","rwt.widgets.GC",{"parent":"w121"}],["set","w121",{"bounds":[0,0,472,0],"children":["w122"],"tabIndex":44,"visibility":false,"foreground":[151,158,164,255],"font":[["Arial","Helvetica","sans-serif"],15,true,false],"backgroundGradient":[[[255,255,255,255],[239,246,250,255]],[0,100],true],"clientArea":[0,0,472,0]}],["create","w122","rwt.widgets.Canvas",{"parent":"w121","style":["NONE"]}],["create","gc211","rwt.widgets.GC",{"parent":"w122"}],["set","w122",{"bounds":[0,1,0,0],"children":["w123"],"tabIndex":45,"visibility":false,"foreground":[151,158,164,255],"background":[0,0,0,0],"font":[["Arial","Helvetica","sans-serif"],15,true,false],"clientArea":[0,0,0,0]}],["create","w123","rwt.widgets.Label",{"parent":"w122","style":["WRAP"],"bounds":[0,0,0,0],"tabIndex":-1,"visibility":false,"foreground":[151,158,164,255],"background":[0,0,0,0],"font":[["Arial","Helvetica","sans-serif"],15,true,false]}],["create","w124","rwt.widgets.Composite",{"parent":"w120","style":["NONE"],"bounds":[0,0,472,144],"children":["w126"],"tabIndex":46,"foreground":[151,158,164,255],"clientArea":[0,0,472,144]}],["create","w126","rwt.widgets.Composite",{"parent":"w124","style":["NONE"],"bounds":[0,0,472,144],"children":["w127"],"tabIndex":-1}],["listen","w126",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w126",{"customVariant":"variant_form","clientArea":[0,0,472,144]}],["create","w127","rwt.widgets.Composite",{"parent":"w126","style":["NONE"],"bounds":[0,0,472,144],"children":["w128"],"tabIndex":-1,"activeKeys":["#27","#13","#13","#13"],"cancelKeys":["#13"]}],["listen","w127",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true,"KeyDown":true}],["set","w127",{"clientArea":[0,0,472,144]}],["create","w128","rwt.widgets.Composite",{"parent":"w127","style":["NONE"],"bounds":[0,0,472,144],"children":["w129","w144"],"tabIndex":-1}],["listen","w128",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w128",{"clientArea":[0,0,472,144]}],["create","w129","rwt.widgets.Composite",{"parent":"w128","style":["NONE"],"bounds":[0,0,472,59],"children":["w130","w131","w132"],"tabIndex":-1}],["listen","w129",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w129",{"customVariant":"variant_groupBoxWithLineFrameContainer","clientArea":[0,6,472,53]}],["create","w130","rwt.widgets.Label",{"parent":"w129","style":["NONE"],"bounds":[14,6,72,17],"tabIndex":-1,"customVariant":"variant_GroupBoxLabel","text":"Social Media"}],["create","w131","rwt.widgets.Label",{"parent":"w129","style":["NONE"],"bounds":[0,23,472,1],"tabIndex":-1,"customVariant":"variant_GroupBoxLine"}],["create","w132","rwt.widgets.Composite",{"parent":"w129","style":["NONE"],"bounds":[0,24,472,35],"children":["w133"],"tabIndex":-1}],["listen","w132",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w132",{"customVariant":"variant_groupBoxWithLineFrame","clientArea":[12,6,448,23]}],["create","w133","rwt.widgets.Composite",{"parent":"w132","style":["NONE"],"bounds":[12,6,448,23],"children":["w134","w139"],"tabIndex":-1}],["listen","w133",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w133",{"clientArea":[0,0,448,23]}],["create","w134","rwt.widgets.Composite",{"parent":"w133","style":["NONE"],"bounds":[0,0,218,23],"children":["w135","w138"],"tabIndex":-1}],["listen","w134",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w134",{"clientArea":[0,0,218,23]}],["create","w135","rwt.widgets.Composite",{"parent":"w134","style":["NONE"],"bounds":[0,0,0,0],"children":["w136","w137"],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w136","rwt.widgets.Label",{"parent":"w135","style":["NONE"],"appearance":"clabel","bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"text":""}],["create","w137","rwt.widgets.Label",{"parent":"w135","style":["NONE"],"bounds":[0,3,0,15],"tabIndex":-1,"visibility":false}],["create","w138","rwt.widgets.Canvas",{"parent":"w134","style":["NONE"]}],["create","gc212","rwt.widgets.GC",{"parent":"w138"}],["set","w138",{"bounds":[0,0,218,23],"children":[],"tabIndex":56,"toolTip":"Twiter","activeKeys":["#13"],"cancelKeys":["#13"]}],["listen","w138",{"KeyDown":true,"MenuDetect":true}],["set","w138",{"clientArea":[0,0,218,23]}],["call","gc212","init",{"width":218,"height":23,"font":[["Arial","Helvetica","sans-serif"],12,false,false],"fillStyle":[255,255,255,255],"strokeStyle":[0,0,0,255]}],["call","gc212","draw",{"operations":[["drawImage","rwt-resources/generated/9c6f6aa4.png",97,0]]}],["create","w139","rwt.widgets.Composite",{"parent":"w133","style":["NONE"],"bounds":[230,0,218,23],"children":["w140","w143"],"tabIndex":-1}],["listen","w139",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w139",{"clientArea":[0,0,218,23]}],["create","w140","rwt.widgets.Composite",{"parent":"w139","style":["NONE"],"bounds":[0,0,0,0],"children":["w141","w142"],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w141","rwt.widgets.Label",{"parent":"w140","style":["NONE"],"appearance":"clabel","bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"text":""}],["create","w142","rwt.widgets.Label",{"parent":"w140","style":["NONE"],"bounds":[0,3,0,15],"tabIndex":-1,"visibility":false}],["create","w143","rwt.widgets.Canvas",{"parent":"w139","style":["NONE"]}],["create","gc213","rwt.widgets.GC",{"parent":"w143"}],["set","w143",{"bounds":[0,0,218,23],"children":[],"tabIndex":60,"toolTip":"Face Book","activeKeys":["#13"],"cancelKeys":["#13"]}],["listen","w143",{"KeyDown":true,"MenuDetect":true}],["set","w143",{"clientArea":[0,0,218,23]}],["call","gc213","init",{"width":218,"height":23,"font":[["Arial","Helvetica","sans-serif"],12,false,false],"fillStyle":[255,255,255,255],"strokeStyle":[0,0,0,255]}],["call","gc213","draw",{"operations":[["drawImage","rwt-resources/generated/aaec9de0.png",97,0]]}],["create","w144","rwt.widgets.Composite",{"parent":"w128","style":["NONE"],"bounds":[0,65,472,79],"children":["w145","w146","w147"],"tabIndex":-1}],["listen","w144",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w144",{"customVariant":"variant_groupBoxWithLineFrameContainer","clientArea":[0,6,472,73]}],["create","w145","rwt.widgets.Label",{"parent":"w144","style":["NONE"],"bounds":[14,6,85,17],"tabIndex":-1,"customVariant":"variant_GroupBoxLabel","text":"Todays Task(s)"}],["create","w146","rwt.widgets.Label",{"parent":"w144","style":["NONE"],"bounds":[0,23,472,1],"tabIndex":-1,"customVariant":"variant_GroupBoxLine"}],["create","w147","rwt.widgets.Composite",{"parent":"w144","style":["NONE"],"bounds":[0,24,472,55],"children":["w148"],"tabIndex":-1}],["listen","w147",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w147",{"customVariant":"variant_groupBoxWithLineFrame","clientArea":[12,6,448,43]}],["create","w148","rwt.widgets.Composite",{"parent":"w147","style":["NONE"],"bounds":[12,6,448,43],"children":["w149"],"tabIndex":-1}],["listen","w148",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w148",{"clientArea":[0,0,448,43]}],["create","w149","rwt.widgets.Composite",{"parent":"w148","style":["NONE"],"bounds":[0,0,448,43],"children":["w150","w153"],"tabIndex":-1}],["listen","w149",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w149",{"clientArea":[0,0,448,43]}],["create","w150","rwt.widgets.Composite",{"parent":"w149","style":["NONE"],"bounds":[0,0,0,0],"children":["w151","w152"],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w151","rwt.widgets.Label",{"parent":"w150","style":["NONE"],"appearance":"clabel","bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"text":"Tasks"}],["create","w152","rwt.widgets.Label",{"parent":"w150","style":["NONE"],"bounds":[0,3,0,15],"tabIndex":-1,"visibility":false}],["create","w153","rwt.widgets.Composite",{"parent":"w149","style":["NONE"],"bounds":[0,0,448,43],"children":["w154"],"tabIndex":-1,"customVariant":"variant_tableField","clientArea":[2,2,442,37]}],["create","w154","rwt.widgets.Grid",{"parent":"w153","style":["MULTI","FULL_SELECTION"],"appearance":"table","indentionWidth":0,"treeColumn":-1,"markupEnabled":true}],["create","w155","rwt.widgets.ScrollBar",{"parent":"w154","style":["HORIZONTAL"]}],["create","w156","rwt.widgets.ScrollBar",{"parent":"w154","style":["VERTICAL"]}],["set","w154",{"bounds":[2,2,442,37],"children":[],"tabIndex":68,"activeKeys":["#13","#32","#13"],"cancelKeys":["#13","#13"]}],["listen","w154",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true,"KeyDown":true,"MenuDetect":true}],["set","w154",{"itemCount":2,"itemHeight":23,"itemMetrics":[[0,0,0,3,0,3,0],[1,0,125,3,0,3,119],[2,125,347,128,0,128,341]],"columnCount":3,"headerHeight":30,"headerVisible":true,"linesVisible":true,"sortDirection":"up","sortColumn":"w159"}],["listen","w154",{"Selection":true,"DefaultSelection":true}],["set","w154",{"enableCellToolTip":true}],["set","w155",{"visibility":true}],["listen","w155",{"Selection":true}],["set","w156",{"visibility":true}],["listen","w156",{"Selection":true}],["create","w157","rwt.widgets.GridColumn",{"parent":"w154","resizable":false}],["create","w158","rwt.widgets.GridColumn",{"parent":"w154","text":"Date","index":1,"width":125,"moveable":true}],["listen","w158",{"Selection":true}],["create","w159","rwt.widgets.GridColumn",{"parent":"w154","text":"Task","index":2,"left":125,"width":347,"moveable":true}],["listen","w159",{"Selection":true}],["create","w160","rwt.widgets.GridItem",{"parent":"w154","index":0,"texts":["InternalTableRow[1, Nov 27, 2013, Audit : Quarterly Audit on Clinical Record Keeping @ 25-Nov-2013]","Nov 27, 2013","Audit : Quarterly Audit on Clinical Record Keeping @ 25-Nov-2013"],"cellFonts":[null,[["Arial","Helvetica","sans-serif"],12,false,false],[["Arial","Helvetica","sans-serif"],12,false,false]]}],["create","w161","rwt.widgets.GridItem",{"parent":"w154","index":1,"texts":["InternalTableRow[2, Nov 27, 2013, Audit : Satisfaction Survey @ 25-Nov-2013]","Nov 27, 2013","Audit : Satisfaction Survey @ 25-Nov-2013"],"cellFonts":[null,[["Arial","Helvetica","sans-serif"],12,false,false],[["Arial","Helvetica","sans-serif"],12,false,false]]}],["create","w37","rwt.widgets.Composite",{"parent":"w27","style":["NONE"],"bounds":[0,0,0,0],"children":["w38","w39"],"tabIndex":69,"visibility":false,"customVariant":"variant_viewPart","clientArea":[0,0,0,0]}],["create","w38","rwt.widgets.Composite",{"parent":"w37","style":["NONE"],"bounds":[0,0,0,64],"children":[],"tabIndex":-1,"visibility":false}],["listen","w38",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w38",{"customVariant":"variant_formTabArea","clientArea":[0,0,0,64]}],["create","w39","rwt.widgets.Composite",{"parent":"w37","style":["NONE"],"bounds":[0,64,0,0],"children":[],"tabIndex":-1,"visibility":false}],["listen","w39",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w39",{"clientArea":[0,0,0,0]}],["create","w40","rwt.widgets.Composite",{"parent":"w27","style":["NONE"],"bounds":[480,3,1437,915],"children":["w41","w42"],"tabIndex":72,"customVariant":"variant_viewPart","clientArea":[0,0,1435,913]}],["create","w41","rwt.widgets.Composite",{"parent":"w40","style":["NONE"],"bounds":[0,0,1435,24],"children":["w162","w190"],"tabIndex":-1}],["listen","w41",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w41",{"customVariant":"variant_formTabArea","clientArea":[0,0,1435,24]}],["create","w162","rwt.widgets.Composite",{"parent":"w41","style":["NONE"],"bounds":[0,0,290,24],"children":["w163","w164"],"tabIndex":74,"customVariant":"variant_formTab","clientArea":[5,2,280,22]}],["create","w163","rwt.widgets.Button",{"parent":"w162","style":["PUSH","FLAT"],"bounds":[5,2,280,18],"tabIndex":75}],["listen","w163",{"FocusIn":true,"FocusOut":true,"KeyDown":true}],["set","w163",{"customVariant":"variant_formTabActivate","text":"Zones - Patient Care - Action Plans - Created","image":["rwt-resources/generated/130a74ec.png",16,16]}],["listen","w163",{"Selection":true}],["create","w164","rwt.widgets.Button",{"parent":"w162","style":["PUSH","FLAT"],"bounds":[285,5,12,12],"tabIndex":76,"visibility":false}],["listen","w164",{"FocusIn":true,"FocusOut":true,"KeyDown":true}],["set","w164",{"customVariant":"variant_formTabClose"}],["listen","w164",{"Selection":true}],["create","w190","rwt.widgets.Composite",{"parent":"w41","style":["NONE"],"bounds":[293,0,80,24],"children":["w191","w192"],"tabIndex":77,"customVariant":"variant_formTab-active","clientArea":[5,2,70,22]}],["create","w191","rwt.widgets.Button",{"parent":"w190","style":["PUSH","FLAT"],"bounds":[5,2,70,16],"tabIndex":78}],["listen","w191",{"FocusIn":true,"FocusOut":true,"KeyDown":true}],["set","w191",{"customVariant":"variant_formTabActivate-active","text":"Dentabyte"}],["listen","w191",{"Selection":true}],["create","w192","rwt.widgets.Button",{"parent":"w190","style":["PUSH","FLAT"],"bounds":[75,4,12,12],"tabIndex":79,"visibility":false}],["listen","w192",{"FocusIn":true,"FocusOut":true,"KeyDown":true}],["set","w192",{"customVariant":"variant_formTabClose"}],["listen","w192",{"Selection":true}],["create","w42","rwt.widgets.Composite",{"parent":"w40","style":["NONE"],"bounds":[0,24,1435,889],"children":["w165","w193"],"tabIndex":-1}],["listen","w42",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w42",{"clientArea":[0,0,1435,889]}],["create","w165","rwt.widgets.Composite",{"parent":"w42","style":["NONE"],"bounds":[0,0,1435,889],"children":["w166"],"tabIndex":-1,"visibility":false}],["listen","w165",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w165",{"clientArea":[0,0,1435,889]}],["create","w166","rwt.widgets.Composite",{"parent":"w165","style":["NONE"],"bounds":[0,0,1435,889],"children":["w171","w167","w170"],"tabIndex":82,"foreground":[151,158,164,255],"font":[["Arial","Helvetica","sans-serif"],15,true,false],"clientArea":[0,0,1435,889]}],["create","w171","rwt.widgets.Composite",{"parent":"w166","style":["NONE"],"bounds":[0,-1,1435,1],"children":[],"tabIndex":-1,"background":[209,228,240,255],"clientArea":[0,0,1435,1]}],["create","w167","rwt.widgets.Canvas",{"parent":"w166","style":["NONE"]}],["create","gc214","rwt.widgets.GC",{"parent":"w167"}],["set","w167",{"bounds":[0,0,1435,0],"children":["w168"],"tabIndex":84,"visibility":false,"foreground":[151,158,164,255],"font":[["Arial","Helvetica","sans-serif"],15,true,false],"backgroundGradient":[[[255,255,255,255],[239,246,250,255]],[0,100],true],"clientArea":[0,0,1435,0]}],["create","w168","rwt.widgets.Canvas",{"parent":"w167","style":["NONE"]}],["create","gc215","rwt.widgets.GC",{"parent":"w168"}],["set","w168",{"bounds":[0,1,0,0],"children":["w169"],"tabIndex":85,"visibility":false,"foreground":[151,158,164,255],"background":[0,0,0,0],"font":[["Arial","Helvetica","sans-serif"],15,true,false],"clientArea":[0,0,0,0]}],["create","w169","rwt.widgets.Label",{"parent":"w168","style":["WRAP"],"bounds":[0,0,0,0],"tabIndex":-1,"visibility":false,"foreground":[151,158,164,255],"background":[0,0,0,0],"font":[["Arial","Helvetica","sans-serif"],15,true,false]}],["create","w170","rwt.widgets.Composite",{"parent":"w166","style":["NONE"],"bounds":[0,0,1435,889],"children":["w172"],"tabIndex":86,"foreground":[151,158,164,255],"clientArea":[0,0,1435,889]}],["create","w172","rwt.widgets.Composite",{"parent":"w170","style":["NONE"],"bounds":[0,0,1435,889],"children":["w173"],"tabIndex":-1}],["listen","w172",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w172",{"customVariant":"variant_form","clientArea":[0,0,1435,889]}],["create","w173","rwt.widgets.Composite",{"parent":"w172","style":["NONE"],"bounds":[0,0,1435,889],"children":["w174"],"tabIndex":-1,"activeKeys":["#27","#13","#13","#13"],"cancelKeys":["#13"]}],["listen","w173",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true,"KeyDown":true}],["set","w173",{"clientArea":[0,0,1435,889]}],["create","w174","rwt.widgets.Composite",{"parent":"w173","style":["NONE"],"bounds":[0,0,1435,889],"children":["w175"],"tabIndex":-1}],["listen","w174",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w174",{"clientArea":[0,0,1435,889]}],["create","w175","rwt.widgets.Composite",{"parent":"w174","style":["NONE"],"bounds":[0,0,1435,889],"children":["w176","w179","w187"],"tabIndex":-1}],["listen","w175",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true}],["set","w175",{"clientArea":[0,0,1435,889]}],["create","w176","rwt.widgets.Composite",{"parent":"w175","style":["NONE"],"bounds":[0,0,0,0],"children":["w177","w178"],"tabIndex":-1,"visibility":false,"clientArea":[0,0,0,0]}],["create","w177","rwt.widgets.Label",{"parent":"w176","style":["NONE"],"appearance":"clabel","bounds":[0,0,0,0],"children":[],"tabIndex":-1,"visibility":false,"text":""}],["create","w178","rwt.widgets.Label",{"parent":"w176","style":["NONE"],"bounds":[0,3,0,15],"tabIndex":-1,"visibility":false}],["create","w179","rwt.widgets.Grid",{"parent":"w175","style":["MULTI","FULL_SELECTION"],"appearance":"table","indentionWidth":0,"treeColumn":-1,"markupEnabled":true}],["create","w180","rwt.widgets.ScrollBar",{"parent":"w179","style":["HORIZONTAL"]}],["create","w181","rwt.widgets.ScrollBar",{"parent":"w179","style":["VERTICAL"]}],["set","w179",{"bounds":[0,0,1435,866],"children":[],"tabIndex":93,"activeKeys":["#13","#32","#13"],"cancelKeys":["#13","#13"]}],["listen","w179",{"MouseDown":true,"MouseUp":true,"MouseDoubleClick":true,"KeyDown":true,"MenuDetect":true}],["set","w179",{"itemCount":1,"itemHeight":23,"itemMetrics":[[0,0,0,3,0,3,0],[1,0,478,3,0,3,472],[2,478,479,481,0,481,473],[3,957,478,960,0,960,472]],"columnCount":4,"headerHeight":30,"headerVisible":true,"linesVisible":true,"focusItem":"w186","selection":["w186"],"sortDirection":"up","sortColumn":"w185"}],["listen","w179",{"Selection":true,"DefaultSelection":true}],["set","w179",{"enableCellToolTip":true}],["listen","w180",{"Selection":true}],["listen","w181",{"Selection":true}],["create","w182","rwt.widgets.GridColumn",{"parent":"w179","resizable":false}],["create","w183","rwt.widgets.GridColumn",{"parent":"w179","text":"Title","index":1,"width":478,"moveable":true}],["listen","w183",{"Selection":true}],["create","w184","rwt.widgets.GridColumn",{"parent":"w179","text":"Created On","index":2,"left":478,"width":479,"moveable":true}],["listen","w184",{"Selection":true}],["create","w185","rwt.widgets.GridColumn",{"parent":"w179","text":"Action Group Count","index":3,"left":957,"width":478,"moveable":true,"alignment":"right"}],["listen","w185",{"Selection":true}],["create","w186","rwt.widgets.GridItem",{"parent":"w179","index":0,"texts":["InternalTableRow[1, 1, , Nov 26, 2013, 1]","","Nov 26, 2013","1"],"cellFonts":[null,[["Arial","Helvetica","sans-serif"],12,false,false],[["Arial","Helvetica","sans-serif"],12,false,false],[["Arial","Helvetica","sans-serif"],12,false,false]]}],["c
Re: Browser field error in RAP client [message #1216740 is a reply to message #1213981] Thu, 28 November 2013 16:05 Go to previous messageGo to next message
Matthias Nick is currently offline Matthias NickFriend
Hi Dominic,
thanks for your question.
What version of Eclipse Scout and RAP are you using?
Greetings,
Matthias
[Updated on: Thu, 28 November 2013 16:10]
Report message to a moderator
Re: Browser field error in RAP client [message #1218640 is a reply to message #1216740] Fri, 29 November 2013 11:12 Go to previous messageGo to next message
Member
the installed version is 3.9.0.20130612-0904
Re: Browser field error in RAP client [message #1218819 is a reply to message #1218640] Fri, 29 November 2013 12:56 Go to previous messageGo to next message
Hi Dominic,
hm... I haven't been able to reproduce the problem.
Can you tell me your RAP version (open your project's rap.product, click on "Dependencies" and doubleclick "org.eclipse.rap.rwt")
Matthias
Re: Browser field error in RAP client [message #1219028 is a reply to message #1218819] Fri, 29 November 2013 20:06 Go to previous message
Lukas Huser is currently offline Lukas HuserFriend
Member
Hi Dominic
I stumbled over the very same issue just yesterday. I also think that this is a cross domain scripting issue.
It is currently not possible to embed an arbitrary external URL in a BrowserField in the RAP client.
The problem is present in Scout 3.9 as well as in the current Scout 3.10 development branch.
I opened a Bugzilla Ticket.
Previous Topic:How to create a read only field
Next Topic:Scout Version Matrix
Current Time: Fri Apr 19 21:56:21 GMT 2024
Powered by FUDForum. Page generated in 0.03430 seconds
