Home » Modeling » EMF » Code Generation Error for Meta Model Element named Enumeration
Code Generation Error for Meta Model Element named Enumeration [message #1213648] Wed, 27 November 2013 10:26 Go to next message
Ralph Gerbig is currently offline Ralph GerbigFriend
I have a meta-model element called Enumeration. When generating code I get an error in the factory class. The code generator does not know which class to use for the Enumeration (The Java one or the Meta-model one). Is there a way to define this in the Ecore or generator model?
Ralph
Re: Code Generation Error for Meta Model Element named Enumeration [message #1213795 is a reply to message #1213648] Wed, 27 November 2013 11:52 Go to previous messageGo to next message
Ralph,
I'm not sure why it should get confused about java.util.Enumeration
(after all, it cal deal with UML2's model that has Class, and Package).
Perhaps you can provide a simple example?
On 27/11/2013 11:26 AM, Ralph Gerbig wrote:
> Hello,
> Ralph
Re: Code Generation Error for Meta Model Element named Enumeration [message #1214075 is a reply to message #1213795] Wed, 27 November 2013 14:29 Go to previous messageGo to next message
Christian W. Damus is currently offline Christian W. DamusFriend
And UML also has a metaclass named "Enumeration"!
cW
On 2013-11-27 11:52:06 +0000, Ed Merks said:
> Ralph,
>> Hello,
>> Ralph
Re: Code Generation Error for Meta Model Element named Enumeration [message #1214253 is a reply to message #1214075] Wed, 27 November 2013 16:07 Go to previous message
In my experience EMF codegen is pretty good about sorting out imports
even for difficulties like Class and Enumeration. This is becuase it
uses the already generated output as input to an updating merge. However
the downside is that if you have bad old content you get equivalently
bad new content.
Sometimes it is important to manually eliminate compilation errors from
your old code before regenerating it. If EMF gets it wrong, manually
correct it and it will probably then regenerate correctly.
Ed Willink
> cW
>> Ralph,
>> Package). Perhaps you can provide a simple example?
>>> Hello,
>>> generator model?
>>> Ralph
Previous Topic:prune & graft on model.
Next Topic:EMF reference and referenced entities as elements in XML
Current Time: Fri Feb 28 13:22:41 GMT 2020
Powered by FUDForum. Page generated in 0.03019 seconds
