Home » Language IDEs » ServerTools (WTP) » Servlet Faces SErvlet is not available
Servlet Faces SErvlet is not available [message #196301] Thu, 12 July 2007 13:51 Go to next message
Originally posted by: Ben.Sisson.ccci.org
In the tutorial "WTP Tutorials - JavaServer Faces Tools Tutorial", when I
run the login.jsp I get the following message: "Servlet Faces Servlet is
not available". Description: The reuqested resource (Servlet Faces
SErvlet is not avaialable) is not available. I'm not sure what I'm
missing in the tutorial and any help would be appreciated.
Ben
Re: Servlet Faces SErvlet is not available [message #196344 is a reply to message #196301] Thu, 12 July 2007 14:02 Go to previous messageGo to next message
Angel Vera is currently offline Angel VeraFriend
Member
Is your project targeting a runtime? Project (right click) -> Properties ->
Targeted Runtime
Ben.Sisson@ccci.org (Ben) wrote in news:e5af23e2c792c9141c8df3116e8dc826$1
@www.eclipse.org:
Angel Vera
WTP Server Tools Developer
Re: Servlet Faces SErvlet is not available [message #196368 is a reply to message #196344] Thu, 12 July 2007 14:15 Go to previous message
The issue was in the properties section of the project. I can't explain
why it wasn't selected but under properties->J2EE Module Dependencies the
SUN-RI libary was not selected. It was visisble but not selected. Also,
under properties->Java Build Path->Order and Export the same libary,
SUN-RI, was present but not selected. I selected both of these and that
eliminated the meessabe.
However, now I receive a new message when I start the project: "The
requested resource(/JSFTutorial/login.faces) is not available. Having
looked around it appears that it seeks this path using the web.xml
<url-pattern>*.faces</url-pattern> parameter. This was pulled fromt the
tutorial as is but I also tried the default patter supplied when creating
the project <url-pattern>/faces/*</url-pattern> and I get the same message
with just an added directory layer. Any help on this would be greatly
apprecaited.
Previous Topic:Beginner Help: Europa and Preview Server
Next Topic:WTP 2.0 and Tomcat instance
Current Time: Mon May 10 03:00:19 GMT 2021
Powered by FUDForum. Page generated in 0.01407 seconds
