Home » Eclipse Projects » GEF » double-click and changing selection programmatically
double-click and changing selection programmatically [message #196233] Fri, 16 September 2005 20:02 Go to next message
Originally posted by: no.yes.maybe
I'll try to rephrase a problem I already posted earlier to make it more
understandable.
I have a diagram editor. When the user double-clicks on a node I want to
programmatically select a different node (I know it sounds weird, but it
makes sense in my app).
I implemented performRequest(Request r) so that if the request is of
type REQ_OPEN I call viewer.setSelection(new
StructuredSelection(otherEditPart));
What happens is that after otherEditPart is selected, the selection
returns on the original node the used double-clicked on. I believe
that's because a selection event is posted due to the clicking on such
node.
Any suggestions on how to achieve the desired functionality?
Roberto
Re: double-click and changing selection programmatically [message #196280 is a reply to message #196233] Sat, 17 September 2005 06:56 Go to previous messageGo to next message
Originally posted by: mvsteenbergen.eljakim.scratch-this.nl
No idea if this works, but maybe you can wrap it in a runnable and run
it on the event thread so it gets executed later?
> understandable.
> node.
> Roberto
Re: double-click and changing selection programmatically [message #196316 is a reply to message #196280] Sat, 17 September 2005 12:24 Go to previous messageGo to next message
Originally posted by: none.unknown.com
Right. Display.asyncExec().
"Martijn van Steenbergen" <mvsteenbergen@eljakim.scratch-this.nl> wrote in
message news:dggsol$2op$1@news.eclipse.org...
> > understandable.
> > node.
> > Thanks,
> > Roberto
Re: double-click and changing selection programmatically [message #196356 is a reply to message #196233] Mon, 19 September 2005 00:17 Go to previous messageGo to next message
This should have been fixed in 3.1.0:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=46757
and then again in 3.1.1
https://bugs.eclipse.org/bugs/show_bug.cgi?id=107752
"roberto" <no@yes.maybe> wrote in message
news:dgfmcs$voo$1@news.eclipse.org...
> understandable.
> I implemented performRequest(Request r) so that if the request is of type
> returns on the original node the used double-clicked on. I believe that's
> because a selection event is posted due to the clicking on such node.
> Roberto
Re: double-click and changing selection programmatically [message #198446 is a reply to message #196233] Tue, 11 October 2005 23:38 Go to previous message
Hi, roberto,
I'm developing a plugin with a graphic model viewer, very similiar to your
work.
The Outline view shows a hierarchycal model. Double-click on the diagram
nodes will "navigate" them
by showing the children of the nodes in main viewer.
I implimented hierarchycal view by modifying the famous Shape:
1. adding field "children" and getChildren() for Shape
2. adding GetModelChildren() for shapeTreeEditPart
The ouline view can show the tree.
My problem is that I can't catch double-click and selection message.
In the shapeTreeEditPart.performRequest(Request r),
I couldn't get the message of the type REQ_OPEN and REQ_SELECTION.
Do you by any chance know why is that?
Thanks!
Miaohua Xu
> understandable.
> Roberto
Previous Topic:GEF Example + Memory Usage
Next Topic:What is SelectionSynchronizer for?
Current Time: Sat Jun 21 08:13:25 EDT 2025
Powered by FUDForum. Page generated in 0.04309 seconds
