Home » Eclipse Projects » GEF » FreeFormLayer#setOpaque(true) prevents multiple selection?
FreeFormLayer#setOpaque(true) prevents multiple selection? [message #196217] Fri, 16 September 2005 22:55 Go to next message
I have run into an issue where on my top level figure, calling
setOpaque(true) so that the bgcolor displays, prevents multiple
selection from working:
protected IFigure createFigure()
IFigure retVal = new FreeformLayer();
// setting this prevents multiple selection from working
retVal.setOpaque(true);
retVal.setBorder(new MarginBorder(3));
retVal.setLayoutManager(new FreeformLayout());
return retVal;
Is there a workaround for this?
/a
Re: FreeFormLayer#setOpaque(true) prevents multiple selection? [message #196324 is a reply to message #196217] Sat, 17 September 2005 16:26 Go to previous messageGo to next message
Originally posted by: none.unknown.com
Override Layer#containsPoint() to act as though the layer's transparent.
However, you won't be able to see any layers underneath the opaque layer.
"Alberto Ricart" <aricart@tibco.com> wrote in message
news:dgfig8$rof$1@news.eclipse.org...
> Hello,
> return retVal;
> /a
Re: FreeFormLayer#setOpaque(true) prevents multiple selection? [message #196364 is a reply to message #196217] Mon, 19 September 2005 04:18 Go to previous message
By multiple selection, do you mean the Marquee selection? The root editpart
returns the marquee drag tracker when asked for a tracker. Probably your
contents editpart is being asked now that it is opaque.
see getDragTracker(...)
> Hello,
> setOpaque(true) so that the bgcolor displays, prevents multiple selection
> from working:
> return retVal;
> /a
Previous Topic:KeyListeners
Next Topic:Need to get the Project name in which I am currently working in
Current Time: Tue Feb 11 14:56:35 GMT 2025
Powered by FUDForum. Page generated in 0.03547 seconds
