Home » Eclipse Projects » NatTable » Traverse in filter row with tab key
Traverse in filter row with tab key [message #1211807] Tue, 26 November 2013 16:33 Go to next message
Alexander Becher is currently offline Alexander BecherFriend
I've tried to add traverse support to the filterrow (especially the TAB key). I've modified the FilterRowGridExample with
configRegistry.registerConfigAttribute(EditConfigAttributes.OPEN_ADJACENT_EDITOR, true, DisplayMode.EDIT, FILTER_ROW);
and the EditSelectionCommand in
org.eclipse.nebula.widgets.nattable.edit.editor.AbstractCellEditor.commit(MoveDirectionEnum direction, boolean closeAfterCommit, boolean skipValidation)
is executed but nothing happens. I guess it is because the filterrow is not selectable and the previous MoveSelectionCommand isn't executed.
Is there another way of doing this via configuration or do I need to change it in my AbstractCellEditor?
Cheers
Alex
Re: Traverse in filter row with tab key [message #1213384 is a reply to message #1211807] Wed, 27 November 2013 08:03 Go to previous message
Dirk Fauth is currently offline Dirk FauthFriend
This is currently not possible because the filter row is not connected to the SelectionLayer. Therefore the command is not executed.
There exists also a ticket for this for quite a while (imported from the SourceForge version)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=379957
I haven't looked into this yet, so I have no solution for you.
Previous Topic:Unable to perform selection when row is added or removed from event list
Next Topic:Info about applied Filter
Current Time: Mon Feb 17 13:22:59 GMT 2020
Powered by FUDForum. Page generated in 0.05631 seconds
