Home » Archived » BIRT » HTML in cross tab?
HTML in cross tab? [message #1211058] Tue, 26 November 2013 08:30 Go to next message
Colin Sutton is currently offline Colin SuttonFriend
One dimension of my crosstab has HTML text for a column heading, stored in
the data cube. How do I set dimension[group1][heading] to interpret the
HTML in the crosstab?
Colin
Re: HTML in cross tab? [message #1211233 is a reply to message #1211058] Tue, 26 November 2013 10:27 Go to previous messageGo to next message
donino donino is currently offline donino doninoFriend
You have to remove the data element from the column heading, and replace it with a text element. In the text editor, set the format to HTML and then use this expression:
<VALUE-OF format="HTML">dimension[group1][heading]</VALUE-OF>
I hope this helps
Re: HTML in cross tab? [message #1213343 is a reply to message #1211233] Wed, 27 November 2013 07:41 Go to previous message
> I hope this helps
Thanks, that was it.
Colin Sutton
Previous Topic:Defining a variable for use in aggregation filters
Next Topic:making birtviewer 3.7.1 compatible for IE9
Current Time: Sun Sep 15 13:34:45 GMT 2024
Powered by FUDForum. Page generated in 0.05121 seconds
