Home » Language IDEs » ServerTools (WTP) » changing context name
changing context name [message #195549] Tue, 03 July 2007 13:14 Go to next message
Zohar Amir is currently offline Zohar AmirFriend
I have a dynamic web project. How do I change my project's context name?
Re: changing context name [message #195565 is a reply to message #195549] Tue, 03 July 2007 13:57 Go to previous messageGo to next message
Kaloyan Raev is currently offline Kaloyan RaevFriend
You have to make an EAR project that adds your Web project.
Then you have to open the application.xml of the EAR project. There you can
modify the context-root tag of your Web module.
If you publish the Web project directly, without including it in an EAR
(e.g. Tomcat) then the context-root value is the name of the Web project.
"zohar" <david_fire4@hotmail.com> wrote in message
news:f6di3f$p58$1@build.eclipse.org...
Re: changing context name [message #195580 is a reply to message #195565] Tue, 03 July 2007 14:27 Go to previous messageGo to next message
Thank you so much for all the help.
"Kaloyan Raev" <kaloyan.raev@sap.com> wrote in message
news:f6dkji$2oi$1@build.eclipse.org...
> can modify the context-root tag of your Web module.
>> Hi,
Re: changing context name [message #195588 is a reply to message #195580] Tue, 03 July 2007 15:03 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry IsaacsFriend
Just to be sure, a Dynamic Web Project has settings for a deploy-name
(found in the org.eclipse.wst.common.component file) and a context-root.
If by "context name" you are referring to the context-root setting,
you can change that in the web project using the Web Project Settings
page of the project's Properties dialog.
Larry
>> you can modify the context-root tag of your Web module.
>> EAR (e.g. Tomcat) then the context-root value is the name of the Web
>> project.
>>> Hi,
Re: changing context name [message #195620 is a reply to message #195588] Wed, 04 July 2007 05:58 Go to previous message
Not sure I understand the difference, but I wanted my project to be deployed
as a different context. I changed the project name and it did the trick (it
actually didn't work right away - can't remember what I did to make it take
affect).
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:f6dofp$p6i$1@build.eclipse.org...
> If by "context name" you are referring to the context-root setting, you
> can change that in the web project using the Web Project Settings page of
> Cheers,
> Larry
>>> project.
>>>> Hi,
>>>> name?
Previous Topic:WTP all-in-one
Next Topic:How to create a new Server for WebSphere 5.1
Current Time: Fri May 14 01:55:15 GMT 2021
Powered by FUDForum. Page generated in 0.01753 seconds
