Home » Archived » Maven Integration (M2E) » Tycho build 0.3.0-DEV-1756
Tycho build 0.3.0-DEV-1756 [message #18653] Tue, 21 October 2008 16:08
Originally posted by: igor.ifedorenko.com
New Tycho build 0.3.0-DEV-1756 has been deployed to
repository.sonatype.org and you can download distribution from [1].
New in this build
* It is possible to share binary artifacts between tycho builds
using maven repositories now. User documentation has not been
updated yet, but integration test [2] should give rough idea
how this feature works.
* Version qualifier expansion has been reworked to better match
PDE/build behaviour. It is enabled by default. Old "timestamp"
plugin has been removed (MNGECLIPSE-973).
* New "eclipse-application" packaging type (MNGECLIPSE-535).
* P2 metadata is generated for update site projects now.
* Directory based bundles can be included in update site and
rcp applications now (MNGECLIPSE-949).
* RCP application packaging honours "unpack" feature.xml
attribute now (MNGECLIPSE-974).
[1]
http://repository.sonatype.org/service/local/repositories/ty cho-pseudo-releases/content/org/codehaus/tycho/tycho-distrib ution/0.3.0-DEV-1756/
[2]
http://svn.sonatype.org/m2eclipse/tycho/trunk/tycho-its/proj ects/tycho164/
m2e/tycho team
Previous Topic:Status of move to Eclipse.org
Next Topic:stable dev build 0.9.7.200810211352 is published
Current Time: Mon Jan 27 01:01:25 GMT 2020
Powered by FUDForum. Page generated in 0.01770 seconds
