about GraphicalViewer's Selection. [message #195509] |
Sun, 11 September 2005 05:48  |
Originally posted by: wudong.liu.gmail.com
As i know, the GraphicalViewer's selection is a collection of EditPart.
I'm wondering if it's possible to change the selection to the model
object instead of EditPart?
Re: about GraphicalViewer's Selection. [message #195524 is a reply to message #195509] |
Sun, 11 September 2005 06:41   |
Originally posted by: mvsteenbergen.eljakim.scratch-this.nl
What exactly are you trying to achieve?
Martijn.
Re: about GraphicalViewer's Selection. [message #195532 is a reply to message #195509] |
Sun, 11 September 2005 06:50   |
Just loop over all those EditParts and getModel()
Re: about GraphicalViewer's Selection. [message #195574 is a reply to message #195524] |
Mon, 12 September 2005 04:02  |
Originally posted by: wudongs.gmail.com
Martijn van Steenbergen 写道:
> Regards,
> Martijn.
> Regards,
> Martijn.
I implements a ViewPart, which listen on some type of selection. it will
check the selection to see if it is a model object, if it is, then
display some information about the model object.
It's only accept type of model, but not EditPart. Of course, i can add
some logic to check if it's a EditPart, and retrieve it's model object.
I just want to know if there some simpler solution in GEF than changing
the existed code.
FUDForum. Page generated in 0.04144 seconds
