(Composite) persistence.xml: NamedQuery of name XYZ not found. [message #1207999] |
Sun, 24 November 2013 22:03  |
Hello everybody,
I am in the process of modularizing a Java EE application (Java EE 7, Glassfish 4, JPA 2.1, EclipseLink 2.5). Everything worked fine so far, but I am currently experiencing a showstopper.
Scenario:
I have an EAR called "myApp.ear" that has dependencies to two EJB/Entity modules represented as JARs called "myModule1.jar" and "myModule2.jar". "myModule2.jar" is also dependent of "myModule1.jar". Each module defines its own persistence.xml in META-INF. The EAR also defines a persistence.xml which serves as the composite persistence.xml.
I have configured everything as explained in the EclipseLink doc.
Everything is working fine: Interaction with JSF modules, EntityManager operations like find(), persist(), etc. Except one thing is constantly going wrong trying to use a named query: "NamedQuery of name XYZ not found". The named queries are all defined in the entities via @NamedQuery. In the unmodularized recent version of the application they are all working fine, I have not changed the original and working code at any point.
I have altered almost every possible setting in the persistence.xml´s like <class>, <mapping-file> and so on. I have varied the persistence.xml´s to death, tried all and everything I could think of, searched the net a hundred times, but sadly there is no solution in sight. I don´t care how I am getting my modularized app to work, I just want it to work without "NamedQuery of name XYZ not found". Any help is greatly appreciated. Here are my persistence units:
"myApp.ear":
<persistence-unit name="myApp" transaction-type="JTA">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<validation-mode>CALLBACK</validation-mode>
<jar-file>myModule1.jar</jar-file>
<jar-file>myModule2.jar</jar-file>
<exclude-unlisted-classes>false</exclude-unlisted-classes>
<properties>
<property name="eclipselink.application-location" value="E:\_dirsync\_snc\htdocs\snc\snc-ejb\src\java\de\blacksmiths\snc\backend\sql\" />
<property name="eclipselink.composite-unit" value="true"/>
<property name="eclipselink.create-ddl-jdbc-file-name" value="ddl_create.sql"/>
<property name="eclipselink.ddl-generation" value="create-tables"/>
<property name="eclipselink.ddl-generation.output-mode" value="both"/>
<property name="eclipselink.drop-ddl-jdbc-file-name" value="ddl_drop.sql"/>
<property name="eclipselink.logging.level" value="FINE"/>
<property name="eclipselink.logging.level.sql" value="FINE"/>
<property name="eclipselink.logging.parameters" value="true"/>
</properties>
</persistence-unit>
"myModule1.jar":
<persistence-unit name="myModule1" transaction-type="JTA">
<jta-data-source>jdbc/myConnectionPool</jta-data-source>
<mapping-file>META-INF/orm.xml</mapping-file>
<class>de.snc.backend.auth.entity.Auth</class>
<class>de.snc.backend.user.entity.User</class>
</persistence-unit>
"myModule2.jar":
<persistence-unit name="myModule2" transaction-type="JTA">
</persistence-unit>
Re: (Composite) persistence.xml: NamedQuery of name XYZ not found. [message #1212343 is a reply to message #1207999] |
Tue, 26 November 2013 21:39   |
Surely also of interest, the stacktrace:
java.lang.IllegalArgumentException: NamedQuery of name: User.selectByEmail not found.
at org.eclipse.persistence.internal.jpa.QueryImpl.getDatabaseQueryInternal(QueryImpl.java:350)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.createNamedQuery(EntityManagerImpl.java:1107)
at com.sun.enterprise.container.common.impl.EntityManagerWrapper.createNamedQuery(EntityManagerWrapper.java:522)
at de.snc.backend.core.control.GenericQueryService.findWithNamedQuery(GenericQueryService.java:35)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.glassfish.ejb.security.application.EJBSecurityManager.runMethod(EJBSecurityManager.java:1081)
at org.glassfish.ejb.security.application.EJBSecurityManager.invoke(EJBSecurityManager.java:1153)
at com.sun.ejb.containers.BaseContainer.invokeBeanMethod(BaseContainer.java:4695)
at com.sun.ejb.EjbInvocation.invokeBeanMethod(EjbInvocation.java:630)
at com.sun.ejb.containers.interceptors.AroundInvokeChainImpl.invokeNext(InterceptorManager.java:822)
at com.sun.ejb.EjbInvocation.proceed(EjbInvocation.java:582)
at org.jboss.weld.ejb.AbstractEJBRequestScopeActivationInterceptor.aroundInvoke(AbstractEJBRequestScopeActivationInterceptor.java:46)
at com.sun.ejb.containers.interceptors.AroundInvokeInterceptor.intercept(InterceptorManager.java:883)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.doCall(SystemInterceptorProxy.java:163)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.aroundInvoke(SystemInterceptorProxy.java:140)
at com.sun.ejb.containers.interceptors.InterceptorManager.intercept(InterceptorManager.java:369)
at com.sun.ejb.containers.BaseContainer.__intercept(BaseContainer.java:4667)
at com.sun.ejb.containers.BaseContainer.intercept(BaseContainer.java:4655)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandler.invoke(EJBLocalObjectInvocationHandler.java:212)
... 97 more
[Updated on: Tue, 26 November 2013 21:40] by Moderator Report message to a moderator
Re: (Composite) persistence.xml: NamedQuery of name XYZ not found. [message #1219088 is a reply to message #1207999] |
Sun, 01 December 2013 16:58   |
Very interesting, when I add
<properties>
<property name="eclipselink.composite-unit.member" value="true"/>
</properties>
to the persistence.xml of "myModule1" and "myModule2" I get the following exception:
SEVERE: Exception while deploying the app [myApp] : Exception [EclipseLink-28030] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: PersistenceUnit [myModule1] specifies eclipselink.composite-unit.member property with value true. That means it cannot be used standalone, but only as a composite member.
It seems that composite persistence.xml does not even get recognized by Glassfish. I really don´t get it ...
Where do I have to put the composite persistence.xml so that it gets recognized? I suppose that it should be sufficient putting it in "myApp.ear/META-INF/persistence.xml"?
Re: (Composite) persistence.xml: NamedQuery of name XYZ not found. [message #1219967 is a reply to message #1219088] |
Sat, 07 December 2013 15:57  |
Ok, this was somehow a fight, but finally it works (although I am not using composite persistence units any more).
If anyone is searching for a solution to modularize a Java EE 7 application that will be deployed to Glassfish, these are very good references:
monica2nto.wordpress.com/2012/01/18/dal-modularizada-en-jpa-con-un-unico-persistenceunit-j2ee/
-> It´s in Spanish, but just translate in a language you understand (e.g. via Google Chrome). The explanations for Websphere also work for Glassfish 4.
stackoverflow.com/a/14971161
stackoverflow.com/a/4076433
-> The same solution as adove, just in other words
If you want any further explanations modularizing the web tier take a look at this, it helped me a lot:
ocpsoft.org/java/jsf-java/how-to-modular-jsf-applications-with-cdi-and-prettyfaces/
stackoverflow.com/a/8320738
Have fun!
[Updated on: Sat, 07 December 2013 16:15] by Moderator Report message to a moderator
FUDForum. Page generated in 0.03412 seconds
