Label does not resize after changing text in GEF 3.1 [message #194733] |
Mon, 05 September 2005 15:22  |
A Label does not resize itself after changing text using the method
setText() in GEF 3.1. Neither revalidate or validate change the size to
accommodate the new text. The only way to solve this issue is to call:
label.setSize(label.getPreferredSize());
Is this the intended behaviour? If this is the case don't you think that it
is more complicated and far less intuitive that the 3.0 behaviour.
Jose M Beleta
Re: Label does not resize after changing text in GEF 3.1 [message #194809 is a reply to message #194733] |
Tue, 06 September 2005 13:27   |
Originally posted by: none.unknown.com
Are you saying this was working in 3.0 and now does not in 3.1? What is the
layout of the label's parent container?
"Jose M Beleta" <beleta@attglobal.net> wrote in message
news:dfhnqq$11g$1@news.eclipse.org...
it
> Jose M Beleta
Re: Label does not resize after changing text in GEF 3.1 [message #195007 is a reply to message #194809] |
Wed, 07 September 2005 13:26   |
Thank you for your reply.
Yes.
> What is the layout of the label's parent container?
I don't know. The parent container is the IFigure obtained using:
GraphicalEditPolicy.getLayer(LayerConstants.FEEDBACK_LAYER);
Jose M Beleta
Re: Label does not resize after changing text in GEF 3.1 [message #195069 is a reply to message #194733] |
Wed, 07 September 2005 19:37   |
The parent must be validated to position the child. If the parent is the
feedback layer, it has no layout so validate is a no-op.
In 3.0, most figures had a bogus default size of 64x32. Maybe this is the
difference?
> it is more complicated and far less intuitive that the 3.0 behaviour.
> Jose M Beleta
FUDForum. Page generated in 0.03944 seconds
