Home » Language IDEs » ServerTools (WTP) » WTP 1.5.4 Problem
WTP 1.5.4 Problem [message #193975] Tue, 05 June 2007 20:10 Go to next message
Originally posted by: ranavishal.gmail.com
Hi All,
I am using wtp 1.5.4 with tomcat 5.5
Can anyone tell me where my dynamic web project are deployed in tomcat
within the eclipse?
The reason I am looking for this because I want to add a file into the
deployed web application in tomcat
Also is there any way to override the deployement of the web projects?
Vishal
Re: WTP 1.5.4 Problem [message #194025 is a reply to message #193975] Wed, 06 June 2007 07:05 Go to previous messageGo to next message
I got the tomcat deployed directory its
workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp 0\wtpwebapps\
for wtp 2.0
but I have to manually copy the files into this directory, Is there a way to
automatically deploy some extra files
I found a file org.eclipse.wst.common.component in .settings folder edited
it to deploy my extra files but
its not copying
Vishal
"Vishal Rana" <ranavishal@gmail.com> wrote in message
news:f44g08$299$1@build.eclipse.org...
> Hi All,
> within the eclipse?
> Thanks
> Vishal
Re: WTP 1.5.4 Problem [message #194042 is a reply to message #194025] Wed, 06 June 2007 12:12 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry IsaacsFriend
If still interested in WTP 1.5.4, see this Tomcat FAQ question:
http://www.eclipse.org/webtools/faq/TomcatServerFAQ.php#info _04
Note that this FAQ still needs to be updated with WTP 2.0 information.
As for copying the extra files, it would help to know what files and
where you want to copy them. I assume just adding them somewhere under
the WebContent folder of your Dynamic Web Project isn't what you are
looking for. Modifying the ".component" file is the only option in some
cases. What were your edits?
Larry
> for wtp 2.0
> its not copying
> Thanks
> Vishal
>> Hi All,
>> within the eclipse?
>> Thanks
>> Vishal
Re: WTP 1.5.4 Problem [message #194143 is a reply to message #194042] Thu, 07 June 2007 09:07 Go to previous messageGo to next message
Thanks Larry
The link was helpful :)
I edited the .component file by adding the following line
<wb-resource deploy-path="/" source-path="/WebContent"/>
to copy the xml file from the project's root directory but it doesn't work
as it should
Vishal
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:f468cc$8ck$1@build.eclipse.org...
> As for copying the extra files, it would help to know what files and where
> you want to copy them. I assume just adding them somewhere under the
> WebContent folder of your Dynamic Web Project isn't what you are looking
> for. Modifying the ".component" file is the only option in some cases.
> Cheers,
> Larry
>> for wtp 2.0
>> to automatically deploy some extra files
>> edited it to deploy my extra files but
>> its not copying
>> Thanks
>> Vishal
>>> Hi All,
>>> within the eclipse?
>>> Thanks
>>> Vishal
Re: WTP 1.5.4 Problem [message #194150 is a reply to message #194143] Thu, 07 June 2007 12:12 Go to previous messageGo to next message
That line looks like the standard line that copies contents of the
"WebContent" folder of your project to the root of the published webapp.
I would assume it was a different line you added.
Larry
Vishal Rana wrote:
> Thanks Larry
> as it should
> Thanks
> Vishal
>> Cheers,
>> Larry
>>> for wtp 2.0
>>> its not copying
>>> Thanks
>>> Vishal
>>>> Hi All,
>>>> within the eclipse?
>>>> Thanks
>>>> Vishal
Re: WTP 1.5.4 Problem [message #194170 is a reply to message #194150] Thu, 07 June 2007 18:14 Go to previous messageGo to next message
oops you are right! actually I added this line
<wb-resource deploy-path="../" source-path="*.xml"/>
news:f48so8$vs4$1@build.eclipse.org...
> "WebContent" folder of your project to the root of the published webapp. I
> Cheers,
> Larry
> Vishal Rana wrote:
>> Thanks Larry
>> work as it should
>> Thanks
>> Vishal
>>> where
>>> Cheers,
>>> Larry
>>>> for wtp 2.0
>>>> way
>>>> its not copying
>>>> Thanks
>>>> Vishal
>>>>> Hi All,
>>>>> within the eclipse?
>>>>> Thanks
>>>>> Vishal
Re: WTP 1.5.4 Problem [message #194178 is a reply to message #194170] Thu, 07 June 2007 19:26 Go to previous messageGo to next message
I'm not sure exactly what <wb-resource> supports, but I wouldn't assume
it supports much more than what WTP needs for "normal" operation. Thus,
I'm doubtful that "*.xml" is valid as a source-path. I would guess that
it needs to point to a folder or a file. Also, the deploy-path of "../"
means you are copying the file to a location outside of the webapp, i.e.
to the "webapps" folder where Tomcat is running. I'm not sure if that
is what you want, or if it is, I'd be somewhat surprised if it worked
correctly. It may need to be "/" for the root of the webapp, or some
subfolder of it. With respect to the source-path, I believe your
choices are to include a <web-resource> for each file individually, or
put them in their own subfolder of your project and specify the subfolder.
Larry
>> Cheers,
>> Larry
>> Vishal Rana wrote:
>>> Thanks Larry
>>> work as it should
>>> Thanks
>>> Vishal
>>>> where
>>>> Cheers,
>>>> Larry
>>>>> for wtp 2.0
>>>>> way
>>>>> its not copying
>>>>> Thanks
>>>>> Vishal
>>>>>> Hi All,
>>>>>> within the eclipse?
>>>>>> Thanks
>>>>>> Vishal
Re: WTP 1.5.4 Problem [message #194185 is a reply to message #194178] Fri, 08 June 2007 09:34 Go to previous message
I tried putting my files into the WebContent folder... and its working :)
My requirement was to put extra files into the project's deployed direcotory
in the tomcat instance
because the contents of the WebContent folder goes directly into the
org.eclipse.wst.server.core\tmp0\wtpwebapps\project's root\ for WTP 2.0
that's why I got my files exactly where I wanted...
Thanks for your support Larry
Cheers
Vishal
news:f49m5t$epm$1@build.eclipse.org...
> I'm not sure exactly what <wb-resource> supports, but I wouldn't assume it
> to the "webapps" folder where Tomcat is running. I'm not sure if that is
> subfolder of it. With respect to the source-path, I believe your choices
> are to include a <web-resource> for each file individually, or put them
> Cheers,
> Larry
>>> Cheers,
>>> Larry
>>> Vishal Rana wrote:
>>>> Thanks Larry
>>>> work as it should
>>>> Thanks
>>>> Vishal
>>>>> where
>>>>> looking
>>>>> cases.
>>>>> Cheers,
>>>>> Larry
>>>>>> for wtp 2.0
>>>>>> way
>>>>>> its not copying
>>>>>> Thanks
>>>>>> Vishal
>>>>>>> Hi All,
>>>>>>> tomcat
>>>>>>> within the eclipse?
>>>>>>> the
>>>>>>> projects?
>>>>>>> Thanks
>>>>>>> Vishal
Previous Topic:Help testing new packages
Next Topic:Dali: Not correctly mapping column name 'class'
Current Time: Tue Apr 16 08:15:03 GMT 2024
Powered by FUDForum. Page generated in 0.85381 seconds
