Re: facet compiler problem [message #193929 is a reply to message #193812] |
Mon, 04 June 2007 15:26 |
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Pierre,
right click on the web project, open "Properties" and take a look at the
category "project facets". Probably something got mixed up there. Normally you
should find Dynamic Web Module in version 2.4, and Java in 1.4. If this is wrong
click on "Add/remove facets" and choose the proper ones.
Hope this helps
Wolgang
Pierre-Henry Perret wrote:
> I have the following message on a web project (WTP 1.5)
> Java compiler doesnt match the version of the installed java project facet
> I run eclipse 3.2.2 with a j2sdk1.4.2 and wtp 1.5
> I cant find the origin of that, have some idea ?
FUDForum. Page generated in 0.02892 seconds
