EditPart with multilayer figure [message #193809] |
Mon, 29 August 2005 10:41  |
--------------030803080304070406040905
Content-Type: text/plain; charset=KOI8-R; format=flowed
I have an EditPart whose figure should be drawn partly
under another EditPart figure partly over it. I have
an EditPart's tree where EditPart3 is a parent of
EditPart1 and EditPart2. See attached picture for details
about their representation.
The question is how to correctly support such figures?
GraphicalEditPart is designed to have only one figure
and only one content pane. However I don't want to split
model object corresponding to EditPart1 into several
EditPart's (one for each layer) because it is only
feature of its representation but not model. Probably, I
should extend GraphicalEditPart with two extra methods
IFigure getFigure(Object layerId) and
IFigure getContentPane(Object layerId), make figure of
EditPart3 multilayered and add parts of EditPart1 and
EditPart2 figures to appropriate layers?
Thanks in advance
Yury
Content-Type: image/bmp;
name="multilayer editpart.bmp"
Content-Disposition: inline;
filename="multilayer editpart.bmp"
Qk22NAYAAAAAADYAAAAoAAAAgAEAAGEBAAABABgAAAAAAIA0BgAAAAAAAAAA AAAAAAAAAAAA
////////////////////////////////////////AAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAA//////////////////////////////////////////// ////////////
//////////////////////////////////////////////////////////// ////AAAA////
////////////////////////////////////AAAA//////////////////// ////////////
////////////////AAAA//////////////////////////////////////// ////////////
//////////////////////////////////////////////////////////// AAAA////////
////////////////////////////////////////AAAA//////////////// ////////////
////////////AAAA//////////////////////////////////////////// ////////////
Re: EditPart with multilayer figure [message #193869 is a reply to message #193809] |
Mon, 29 August 2005 14:53   |
Depending on your requirements, perhaps EditPart1 just needs to add a second
figure to another layer. Could you provide more details of what you are
going? Is this a common diagram type?
"Yury Semikhatsky" <sys2002@yandex.ru> wrote in message
news:deuooc$87j$1@news.eclipse.org...
> Thanks in advance
> Yury
Re: EditPart with multilayer figure [message #193923 is a reply to message #193869] |
Mon, 29 August 2005 15:38   |
--------------070509090804020504000401
I'm working on Sequence Diagram from UML2.0 And there is
lifelines and combined fragments. Combined fragments can
cover several lifelines and can be nested one into
another(as shown on attached picture). Also I want to fill
background of combined fragments with different colors.
I think that combined fragments should be multilayered(one
layer for filled background and one for outline frame).
Lifelines should be placed on the middle layer. But I
cannot just add different parts of combined fragments on
different layers, I must add them to appropriate parts of
containing combined fragment(background should lie in
background and outline frame should lie in outline frame).
On EditPart deleting it should remove figure compartments
from containers on different layers. That is why I want to
have support of multilayered figures in EditPart's.
>>Hi,
>>Thanks in advance
>>Yury
name="sd.bmp"
filename="sd.bmp"
Qk3eEwgAAAAAADYAAAAoAAAAtwEAAJEBAAABABgAAAAAAKgTCAAAAAAAAAAA AAAAAAAAAAAA
////////////////////////////AAAA//////////////////////////// ////////////
////////////////////AAAA//////////////////////////////////// ////////////
////////////////////////////////////////////////////AAAA//// ////////////
////////////////////////////////////////////AAAA//////////// ////////////
////AAAA//////////////////////////////////////////////////// ////////////
//////////////////////////////////////////////////////////// ////////AAAA
////////////////////////AAAA//////////////////////////////// ////////////
AAAA//////////////////////////////////////////////////////// ////////////
////////////////////////////////////////////////////////AAAA ////////////
////////////////////////////////AAAA//////////////////////// ////////////
////////////////////////////////////////////////AAAA//////// ////////////
////////AAAA//////////////////////////////////////////////// ////////////
Re: EditPart with multilayer figure [message #194118 is a reply to message #193923] |
Tue, 30 August 2005 20:00  |
You can definitely do this by just adding a second figure to your editpart
and inserting it on another layer. Override addNotify and removeNotify to
hook the point at which you should add the secondary figure.
FUDForum. Page generated in 0.07080 seconds
