Re: Can't add cURL plugin [message #1205432 is a reply to message #1203611] |
Sat, 23 November 2013 16:10   |
On 11/22/2013 12:05 PM, Jim Gardner wrote:
> Good afternoon.
> I am trying to install the cURL plugin and it fails on the install.
> When I go to the screen to add the plugins and enter the URl:
> www.curl.com/cde.update-site.win32/ it does produce a number of install
> 6 options i.e. Curl Development environment (English) however when I
> select the "Show software only applicable to target environment the Curl
> Development Enviroment (English) and the other two disappear.
> What do I need to do to be able to have cURL plugin installed?
> Here is the info on the Eclipse install:
> Eclipse Standard/SDK
> Version: Kepler Service Release 1
> Build id: 20130919-0819
> eclipse.buildId=4.3.0.M20130911-1000
> Thank you very much for any help/direction to get this resolved. If
> additional information is needed please let know.
> Again, thank you.
> Jim
You may discover that you must resort to the third party that wrote this
plug-in, which isn't developed by the Eclipse community. You may not
necessarily get an answer in this forum.
FUDForum. Page generated in 0.03054 seconds
