Home » Eclipse Projects » GEF » Grouping components for a drag
Grouping components for a drag [message #193217] Wed, 24 August 2005 17:25 Go to next message
Originally posted by: gef.oppacher.ca
I'm trying to select a set of editparts when another editpart is selected
for dragging. When component A is selected for dragging I also want
components B, C, and D to also be selected for the components. I am
essentially trying to do what the marquee tool does but on the fly. I
created a DragTracker and overrid the handleDragStarted() method to select
the other components by using the appendSelection method in
GraphicalViewer. By doing this selection it seems to interupt my drag so
the objects don't actually move. Is there a better place to put this where
it won't override the drag?
Re: Grouping components for a drag [message #193248 is a reply to message #193217] Wed, 24 August 2005 18:42 Go to previous messageGo to next message
Originally posted by: bashar.infromatik.uni-bonn.de
You may try with implementing EditPartListener and register it with the
editparts which will then be notified by
EditPartListener#selectedStateChanged(EditPart editpart). @see
GraphicalEditPart#setSelected() for selecting others.
"Yandu" <gef@oppacher.ca> wrote in message
news:1d9e30770ea568ee686d112e89c85dfd$1@www.eclipse.org...
Re: Grouping components for a drag [message #193284 is a reply to message #193248] Wed, 24 August 2005 20:28 Go to previous messageGo to next message
Selecting the other parts using GraphicalEditPart#setSelected() is exactly
what GraphicalViewer#appendSelection() does. It seems that when I add to
my selection group gef trets this as if the drag has finished since each
part that I add gains focus be default. So either I can override the
appendSelection method which I don't want to do or figure out how to
regenerate a drag request. Any ideas on how to do this?
>> Hi,
Re: Grouping components for a drag [message #193310 is a reply to message #193284] Wed, 24 August 2005 21:27 Go to previous messageGo to next message
Yes, you are right. I tried using EditPartListener & EditPart#setSelected().
All others are selected as well but only the first one moves.
Sorry, I don't have any other idea, but I think overriding appendSelection
should work.
regards
news:f6217bb06d79cb8e92e2b5cdd1a6841f$1@www.eclipse.org...
> Thanks
>>> Hi,
>>> selected for dragging. When component A is selected for dragging I also
>>> want components B, C, and D to also be selected for the components. I am
>>> select the other components by using the appendSelection method in
>>> where it won't override the drag?
Re: Grouping components for a drag [message #193350 is a reply to message #193310] Thu, 25 August 2005 13:58 Go to previous message
I managed to get it working by updating the operationSet List in
AbsractTool to include all newly selected EditParts. I also had to
setState(STATE_DRAG_IN_PROGRESS). Thanks for your help.
Yandu
> should work.
> regards
>> Thanks
>>>> Hi,
Previous Topic:How to get the EditPart at the mouse location?
Next Topic:Invoking a GEF application / getSite
Current Time: Mon Feb 10 01:21:47 GMT 2025
Powered by FUDForum. Page generated in 0.26260 seconds
