Home » Eclipse Projects » GEF » Polyline does not appear
Polyline does not appear [message #193071] Wed, 24 August 2005 09:33 Go to next message
I have got a problem with a Polyline.
I have added a polyline to the draw2d demo 4 (eclipse help), but this
line does not appear. What's wrong?
Here my code.
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.draw2d.*;
import org.eclipse.draw2d.geometry.*;
public class Demo4 {
public static void main(String args[]){
Shell shell = new Shell();
shell.setSize(350,350);
shell.open();
shell.setText("Demo 4");
LightweightSystem lws = new LightweightSystem(shell);
IFigure panel = new Figure();
//panel.setLayoutManager(new XYLayout());
lws.setContents(panel);
RectangleFigure
node1 = new RectangleFigure(),
node2 = new RectangleFigure();
RectangleFigure node3 = new RectangleFigure();
Polyline line=new Polyline();
PointList list = new PointList();
//NEW
list.addPoint(10,10);
list.addPoint(20,120);
line.setBackgroundColor(ColorConstants.black);
line.setLineWidth(10);
line.setPoints(new PointList());
node1.setBackgroundColor(ColorConstants.red);
node1.setSize(64, 36);
node2.setBackgroundColor(ColorConstants.blue);
//node2.setLocation(new Rectangle(100, 100, 64, 36));
node2.setSize(40,50);
//node3.setSize(100,100);
//node3.setLocation(new Point(200,200));
PolylineConnection conn = new PolylineConnection();
conn.setSourceAnchor(new ChopboxAnchor(node1));
conn.setTargetAnchor(new ChopboxAnchor(node2));
conn.setTargetDecoration(new PolygonDecoration());
Label label = new Label("MidpointAAAA");
label.setOpaque(true);
label.setBackgroundColor(ColorConstants.buttonLightest);
label.setBorder(new LineBorder());
conn.add(label, new MidpointLocator(conn, 0));
panel.add(node1);
panel.add(node2);
//panel.add(node3);
//New
panel.add(line);
panel.add(conn);
new Dragger(node1);
new Dragger(node2);
Display display = Display.getDefault();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep ();
static class Dragger extends MouseMotionListener.Stub implements
MouseListener {
public Dragger(IFigure figure){
figure.addMouseMotionListener(this);
figure.addMouseListener(this);
Point last;
public void mouseReleased(MouseEvent e){}
public void mouseClicked(MouseEvent e){}
public void mouseDoubleClicked(MouseEvent e){}
public void mousePressed(MouseEvent e){
last = e.getLocation();
public void mouseDragged(MouseEvent e){
Point p = e.getLocation();
Dimension delta = p.getDifference(last);
last = p;
Figure f = ((Figure)e.getSource());
f.setBounds(f.getBounds().getTranslated(delta.width,
delta.height));
Re: Polyline does not appear [message #193081 is a reply to message #193071] Wed, 24 August 2005 10:59 Go to previous messageGo to next message
Your polyline doesn't know were to appear. Use: line.setPoints(list);
Welcome to draw2D.
michael
"Jens" <jens.bartelheimer@gmx.de> schrieb im Newsbeitrag
news:deheud$sm1$1@news.eclipse.org...
> Hello,
> Here my code.
> import org.eclipse.swt.widgets.Display;
> shell.open();
> RectangleFigure
> //NEW
> panel.add(node1);
> panel.add(node2);
> //panel.add(node3);
> //New
> panel.add(line);
> panel.add(conn);
> new Dragger(node1);
> new Dragger(node2);
> display.sleep ();
> MouseListener {
> Point last;
> last = p;
> delta.height));
Re: Polyline does not appear [message #193301 is a reply to message #193081] Wed, 24 August 2005 20:52 Go to previous message
thanks,
stupid mistake ;-)
> Welcome to draw2D.
> michael
>>Hello,
>>Here my code.
>> shell.open();
>> RectangleFigure
>>//NEW
>> panel.add(node1);
>> panel.add(node2);
>> //panel.add(node3);
>>//New
>> panel.add(line);
>> panel.add(conn);
>> new Dragger(node1);
>> new Dragger(node2);
>> display.sleep ();
>>MouseListener {
>> Point last;
>> last = p;
>>delta.height));
Previous Topic:Controlling order in which selected items are processed
Next Topic:position and reposition Figure’s children
Current Time: Tue Feb 11 23:13:16 GMT 2025
Powered by FUDForum. Page generated in 0.07789 seconds
