Home » Modeling » Papyrus » Unexpected Error by the Properties View(Trouble understanding this unusual Unexpected Error which seems to be caused by the Properties View)
Unexpected Error by the Properties View [message #1201204] Thu, 21 November 2013 16:26 Go to next message
Damjan Temelkovski is currently offline Damjan TemelkovskiFriend
I was just wondering if someone has encountered this error and knows a workaround. I am working on Kepler (4.3.1) with Papyrus 0.10.1 and MARTE 0.10.0. I assume I messed something up testing out all the MARTE functionalities.
The error message is "Unexpected Error" it seems to come from org.eclipse.papyrus.views.properties
Here's the stack trace:
org.eclipse.papyrus.infra.core.services.ServiceNotFoundException: Can't find the ResourceSet needed retrieve the ServiceRegistry.
	at org.eclipse.papyrus.infra.emf.utils.ServiceUtilsForResource.getServiceRegistry(ServiceUtilsForResource.java:64)
	at org.eclipse.papyrus.infra.emf.utils.ServiceUtilsForEObject.getServiceRegistry(ServiceUtilsForEObject.java:43)
	at org.eclipse.papyrus.views.properties.modelelement.EMFModelElement.getLabelProvider(EMFModelElement.java:202)
	at org.eclipse.papyrus.views.properties.modelelement.DataSource.getLabelProvider(DataSource.java:165)
	at org.eclipse.papyrus.views.properties.widgets.MultiReferencePropertyEditorWithPropertyView.doBinding(MultiReferencePropertyEditorWithPropertyView.java:44)
	at org.eclipse.papyrus.views.properties.widgets.AbstractPropertyEditor.checkInput(AbstractPropertyEditor.java:158)
	at org.eclipse.papyrus.views.properties.widgets.AbstractPropertyEditor.setProperty(AbstractPropertyEditor.java:233)
	at sun.reflect.GeneratedMethodAccessor215.invoke(Unknown Source)
	at org.eclipse.papyrus.xwt.javabean.metadata.properties.BeanProperty.setValue(BeanProperty.java:89)
	at org.eclipse.papyrus.xwt.javabean.ResourceLoader.initSegmentAttribute(ResourceLoader.java:1546)
	at org.eclipse.papyrus.xwt.javabean.ResourceLoader.initAttribute(ResourceLoader.java:1356)
	at org.eclipse.papyrus.xwt.javabean.ResourceLoader.init(ResourceLoader.java:1008)
	at org.eclipse.papyrus.xwt.javabean.ResourceLoader.doCreate(ResourceLoader.java:618)
	at org.eclipse.papyrus.xwt.javabean.ResourceLoader.doCreate(ResourceLoader.java:648)
	at org.eclipse.papyrus.xwt.javabean.ResourceLoader.createUIElement(ResourceLoader.java:356)
	at org.eclipse.papyrus.xwt.internal.core.Core.createCLRElement(Core.java:619)
	at org.eclipse.papyrus.xwt.internal.core.Core.load(Core.java:736)
	at org.eclipse.papyrus.xwt.internal.core.Core.load(Core.java:646)
	at org.eclipse.papyrus.xwt.XWTLoader.loadWithOptions(XWTLoader.java:1022)
	at org.eclipse.papyrus.xwt.XWTLoader.load(XWTLoader.java:605)
	at org.eclipse.papyrus.xwt.XWT.load(XWT.java:435)
	at org.eclipse.papyrus.views.properties.runtime.DefaultDisplayEngine.createSection(DefaultDisplayEngine.java:186)
	at org.eclipse.papyrus.views.properties.runtime.DefaultDisplayEngine.createSection(DefaultDisplayEngine.java:145)
	at org.eclipse.papyrus.views.properties.xwt.XWTSection.display(XWTSection.java:151)
	at org.eclipse.papyrus.views.properties.xwt.XWTSection.refresh(XWTSection.java:161)
	at org.eclipse.papyrus.views.properties.creation.EditionDialog.display(EditionDialog.java:251)
	at org.eclipse.papyrus.views.properties.creation.EditionDialog.create(EditionDialog.java:109)
	at org.eclipse.jface.window.Window.open(Window.java:791)
	at org.eclipse.papyrus.views.properties.creation.PropertyEditorFactory.createObject(PropertyEditorFactory.java:95)
	at org.eclipse.papyrus.views.properties.creation.EcorePropertyEditorFactory.createObject(EcorePropertyEditorFactory.java:196)
	at org.eclipse.papyrus.infra.widgets.editors.ReferenceDialog.createAction(ReferenceDialog.java:216)
	at org.eclipse.papyrus.infra.widgets.editors.ReferenceDialog.widgetSelected(ReferenceDialog.java:380)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
I know this is unusual, but would appreciate some more info if someone has seen it before
Thank you,
Damjan
Re: Unexpected Error by the Properties View [message #1201213 is a reply to message #1201204] Thu, 21 November 2013 16:32 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
Hi Damjan,
This is a known issue, related to the creation of new elements from the properties view. This error doesn't have any side effect (except for filling the error log). You should ignore it. It cannot be avoided (yet Smile )
This is a side effect of:
402525: [Widgets / Transactions] Papyrus dialogs should be transactional
https://bugs.eclipse.org/bugs/show_bug.cgi?id=402525
Camille
Camille Letavernier
Re: Unexpected Error by the Properties View [message #1201473 is a reply to message #1201213] Thu, 21 November 2013 19:17 Go to previous messageGo to next message
Thank you very much Camille,
Sorry for posting before reading enough, although I doubt I would've realized what had caused this.
Thanks again,
Damjan
Re: Unexpected Error by the Properties View [message #1203528 is a reply to message #1201473] Fri, 22 November 2013 18:09 Go to previous message
I just want to specify that this happens in the Properties View of a Constraint with <<timedConstraint>> when I click on the green "+" for Specification and try to add a new OpaqueExpression. This may be redundant information, but I thought I'd share.
Damjan
Previous Topic:Sequence Diagrams Time Constraints
Next Topic:MARTE and SysML stereotypes brake OCL text editor
Current Time: Mon Jan 25 21:34:26 GMT 2021
Powered by FUDForum. Page generated in 0.02085 seconds
