PDT installed but not working [message #1200186] |
Thu, 21 November 2013 05:50 |
Jake Moe Messages: 3 Registered: November 2013 |
Hi all,
I've downloaded and installed Eclipse Kepler on Windows 7, and from Install New Software, I installed PDT. It tells me that it's installed (the icon has changed in Install New Software, and in Installation Details --> Installed Software, it's there as well). However, when I go in to Preferences, there is no PHP section. When I go to create a new project, there is no PHP option. If I open an existing PHP file, there is no syntax colouring.
I've Googled around for a solution, but have been unable to find it on my own. The closest I've come is another post on here that sounds the same, but from Juno, not Kepler, and it only had a few answers, and appears to have never been solved.
Does anyone have any suggestions on how I might be able to get PDT working? The rest of the Eclipse install seems fine: I can create and run Java apps, and I've added and installed the Android Development Kit, and it works fine as well. Just PDT seems to be broken.
Any assistance would be appreciated. Thanks.
Re: PDT installed but not working [message #1244239 is a reply to message #1220032] |
Wed, 12 February 2014 04:02 |
I've finally managed to get this working on the Windows 7 machines I was having this trouble with, but it didn't work on the Windows 8.1 machine. In case it helps, I did two things:
- I went into Help --> About Eclipse --> Installation Details, selected PHP Development Tools (PDT), uninstalled it, and restarted Eclipse. I then installed "Dynamic Languages Toolkit - Core Frameworks", "Dynamic Languages Toolkit - Core H2 Index Frameworks", and "PHP Development Tools (PDT)" one at a time, restarting Eclipse after installing each one.
- I went into the eclipse.ini in my installation folder, and changed the two bottom values to -Xms1024m and -Xmx1024m
However, when I did both of these on the Win 8.1 box, it didn't work. :-/ Maybe it was just the uninstall and reinstall decided to allow it to work this time?
FUDForum. Page generated in 0.08008 seconds
