Re: Compare two arraylist of EMF objects [message #1200585 is a reply to message #1199623] |
Thu, 21 November 2013 10:01 |
Ed Merks Messages: 33140 Registered: July 2009 |
Phil,
Comments below.
On 21/11/2013 12:14 AM, Phil H wrote:
> I've got two ArrayList which contains of objects from type Hardware.
> This class has got an Enumeration "ElementType", which should be used
> to compare different objects of hardware to each other.
> I'm wonder now how I can make use of helper methods like
> java.util.AbstractCollection.containsAll to compare my ArrayLists.
It sounds like you should do this external to the list implementation.
> As the objects are different, equals method gave a false back. Is
> there a way to customize the equals method or solve this in another way?
It's not clear what you're hoping to achieve. Doesn't
org.eclipse.emf.ecore.util.EcoreUtil.equals(List<? extends EObject>,
List<? extends EObject>) help?
> Cheers,
> Phil
Ed Merks
FUDForum. Page generated in 0.03554 seconds
