Problems trying to install cURL plugin [message #1197214] |
Tue, 19 November 2013 20:16 |
Jim Gardner Messages: 2 Registered: November 2013 |
Good afternoon.
I am trying to install the cURL plug in for Eclipse and it is failing.
I am using this site: www.curl.com/cde.update-site.win32/ to retrieve cURL
I then get the screen that displays the different languages. When I check the box that reads : "Show only software applicable to target environment" the "Curl Development Environment (English) disappears as well as the other languages.
I don't understand what is causing this to happen. The end result is that I am unable to get cUrl installed.
The Eclipse version is :
Build id : 20130919-0819
eclipse.buildId=4.3.0.M20130911-1000
Installed packages are :
Eclipse Standard /SDK
PHP Development tools
I would apprecaite any help/guidance/suggestions that can be offered.
Thank you very much for your help.
Jim
FUDForum. Page generated in 0.03302 seconds
